Home > 998cc > using a 940 head and a decompression plate and 2 head gaskets.
booton
Member #: 9792
has any ones used a decompression plate. any issues.
found a high quility one
http://www.ebay.co.uk/itm/Classic-Mini-Dec...5#ht_570wt_1165
could easily lower the compression and not pay over the odds for a 295 head.
just a thought.
Carl S
Member #: 1761
Stalker
Have a search booton, this has been discussed lots of times before.
Carl.
de comp plates are a bodge
bennyy
Member #: 9037
Doncaster, yorkshire
For the price of a de comp plate and 2 headgaskets your nearly at the price of one of the head gurus opening out your chambers, benross or turbo phill can do this.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
what he said!
Cant think of any circumstances I'd ever consider using a decompression plate.
What makes you say they are a quality item,
just a thought.
booton
Member #: 9792
fair enough,
thanks for your reply's.
guess its not worth it then.
thanks for the advice.
booton ,
in case it helps , i know of two turbo mini engines running with two head gaskets ,up to 12 psi , neither suffered any problems .
i also know of a turbo min running 15 psi with water meth inj using a 1.8mm stainless spacer plate with one gasket either side . it never blew either .
editted to add ,
i completely forgot !! my own 498cc bike uses a decomp plate ,i knocked up from a sheet of 1.8mm mild steel ,been fine for 10 years on 15 psi ,135 bhp .11000rpm max .
Edited by robert on 12th Feb, 2012.
I think a decomp plate is a bit of a bodge, but there are several reasons where there is a god argument to use on.
One important point if you do decide to use one. The link you have is for a small bore. If you are using a 12G940 you need a largbore plate and largebore head gaskets.
Alex
Member #: 1851
Woolavington, Zummerzet
Some years ago a friend obtained a development A-Series head from the back door of the factory that was totally flat - no combustion chambers at all. To get a sensble compression ratio he had to run a decomp plate and was forever blowing gaskets.
One quick chat with the metallurgists at work later, he had another plate made up out of cast iron - and never blew another gasket.
All the commercially available plates I've seen are made of aluminium, which has a dramatically different expansion ratio to cast iron - best guess was that the plate tears the gaskets during warm up/cool down.
