Home > Introduce Yourself > newie
purpsmini
Member #: 9804
i have 76 leyland cluman s just starting on building a engine i have following gt17 turbo no manifolds just turbo after manifold n so on i have 1275 cooper s head ported polished thin 37 n 31 mm valves with direct in ports methonal injection stock block ready to be dipped n bored surposad 1275 crank ground to be stroker 1440 dont know if this is true would love to know measurment to find out if it is 100hp shot nos waiting to go on havent worked cam oil pump n vavle springs yet sorry and 60 thou over dished pistons some help would be great
Woah!
I think you need to use this link!
http://www.lmgtfy.com/?q=how+to+contruct+a+sentence
Welcome to TM btw.
hazpalmer
Member #: 9038
Carlisle, Cumbria
welcome
1380rich
Member #: 9766
Warwickshire
Welcome to tm
Avon 2010 class c 3rd
purpsmini
Member #: 9804
yeah sorry im not good with that didnt get a great education growing up
welcome to TM
wng691s clubby
Member #: 9252
Cleethorpes
welcome sounds like an interesting mini
Done now needs redoing lol
well it all here for you ...welcome aboard
alaskanow0
Member #: 8466
Mansfield
Sounds like a mental build. You will need Cooper S Rods to stroke the crank, Those valve sizes are too big for a turbo motor. 100bhp Nos will kill the engine. Ive found 40bhp the limit on an a series, after that it as a negative effect.
Edited by alaskanow0 on 14th Feb, 2012.
purpsmini
Member #: 9804
thanks for the help guy i got crank off has cooper s rods for the nitrated crank but turned out to be standard not stroked
purpsmini
Member #: 9804
having problem with 1000cc in it atm,cold runs great hot drops cylinders no spark till cold i have post in teck support
