| Home > Help Needed / General Tech Chat > why dont my brakes work? | |||||||
1st May, 2005 at 04:10:44pm
hello all, hope your enjoying the sun |
1st May, 2005 at 05:31:11pm
erm, sounds silly but.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
1st May, 2005 at 06:34:47pm
sounds a daft question did you bleed the whole brake setup? i've had a similar result before but after bleeding all 4 corners in the right order the pedal was alot better! |
1st May, 2005 at 08:50:51pm
start with the furthest brake from master cylinder clamp off the 3 flex hoses of the brakes your not bleeding at that time (if you have rubber not braided ) Crystal Sound Audio said:
1st May, 2005 at 08:51:42pm
i only have 2 nipples (thank god), both at the top!!
Edited by Nic on 1st May, 2005. |
2nd May, 2005 at 06:53:57am
im having simlar probs with my four pots, but im thinking its the master cylinder is the problem, dont no about you greypride but im using a cooper s mc, and im thinking that the internal piston bore size in the mc is not big enough so this will give a greater brake travel.
2nd May, 2005 at 09:50:57am
if you a`re "SURE" you have got all the air out!!
2nd May, 2005 at 10:30:06am
A new master cylinder is £100 I think from Minispares.
Edited by Vegard on 2nd May, 2005. On 13th Jul, 2012 Ben H said:
2nd May, 2005 at 10:32:14am
I know you aren't keen on a pressure bleeding kit but why not? If you use an old wheel and tyre and let it down to around 20psi before you start then you don't cover everything in brake fluid?
2nd May, 2005 at 10:35:26am
On 02/05/2005 06:53:57 turbo hogster said:
im having simlar probs with my four pots, but im thinking its the master cylinder is the problem, dont no about you greypride but im using a cooper s mc, and im thinking that the internal piston bore size in the mc is not big enough so this will give a greater brake travel. but am i barking up the wrong tree here Smaller piston size at the master cylinder will give a "lighter" pedal e.g. less effort to stop the car. A larger m/c gives a "heavier" pedal e.g. more effort required to stop the car. As long as the brakes are adjusted and bled up correctly, the master cylinder bore should not have a great effect on the pedal "length"(or travel).
2nd May, 2005 at 11:11:26am
On 02/05/2005 10:35:26 Tom Fenton said:
Smaller piston size at the master cylinder will give a "lighter" pedal e.g. less effort to stop the car. A larger m/c gives a "heavier" pedal e.g. more effort required to stop the car. Isn't it the other way around? With a large dimater piston, more fluid is moved per centimeter of travel. This surely will make the pedal heavier? Or is it lbs/square inch? Bigger bore means bigger area and less lbs per SI... It's been so l ong since I had physics now.... :) On 13th Jul, 2012 Ben H said:
2nd May, 2005 at 11:37:04am
I always get this bloody wrong.......I'll work it out for me as much as anyone else.......
2nd May, 2005 at 12:36:52pm
its a new master cylinder, the plastic bean can style
2nd May, 2005 at 01:23:51pm
I had a problem with a set of 4 pots once, the drillings between the pots on one side of the caliper had wandered during manufacture, meaning that the fluid was effectively blocked off by the seal. When trying to pump the pedal, it was very spongy, and one piston refused to move full stop. When you press the pedal do all the pistons move?
2nd May, 2005 at 09:17:09pm
thanks for persisting
2nd May, 2005 at 10:48:31pm
Give you £100 for them... On 17th Nov, 2014 Tom Fenton said:
2nd May, 2005 at 10:51:41pm
Ruthless f***er!!!
3rd May, 2005 at 11:27:57am
i would shop around for the master cylinder
6th May, 2005 at 12:38:05am
theyre my second set from them, the first were the cast ones that leaked fluid
6th May, 2005 at 10:05:47pm
Just replaced complete pipes cylinders servo on a golf,bled 4 times no pedel......got a brand new easy bleed kit and perfect.
6th May, 2005 at 11:21:05pm
had the same over the years the pipes perished
7th May, 2005 at 10:49:39am
hmmmmm, i may possibly consider buying another then, but im not keen
9th May, 2005 at 07:50:59pm
the best one ive seen is a 99p pearl which is a piece of pipe with a split in it with a stud at the end works a bloody treat and my last one ive had for years. always looking for them bigger bunches of bannanas |
9th May, 2005 at 07:52:52pm
I bought one of those once. Except mine didn't have a split in it, so as soon as you pressed the pedal it shot the stud out never to be seen again. I couldn't figure out how it was supposed to work so I had a strop and set it on fire.
9th May, 2005 at 09:22:42pm
oh hang on, are you talking about the thing that you connect up to a tyre to bleed, or the tubes that you slip on your nipples and only allow air and fluid to go out, but nothing to go back in??
