Home > Beginners Tech > Downdraught weber for boost
carl talbot
Member #: 1323
Can anyone suggest a downdraught weber for a low boosted [5-8psi] 1200cc motor
Are all weber carbs ok to use with low boost
or do they need seals , float chamber etc changing
Everything needs to be sealed and pressurised float bowl under any sort of boost or it'll run lean, unless you use it suckthrough.
Isn't the R5 carb a down draught?
Even if it is though it has a bad reputation. Why do you want one over the HIF44?
