Home > Beginners Tech > light weight backplate and flywheel setup
wng691s clubby
Member #: 9252
Cleethorpes
just got a new light weight setup from john got it all bolted together fine but how do i work out how much i need skimming off the backplate lugs. I have tryd to search but couldnt find anything
Done now needs redoing lol
Why do you want to skim them?
wng691s clubby
Member #: 9252
Cleethorpes
to get the clutch spring flat?
http://www.minimania.com/web/SCatagory/CLU...53/ArticleV.cfm
What thickness are your 3 spacers?
wng691s clubby
Member #: 9252
Cleethorpes
10.4mm
You shouldnt need to skim anything at thickness
Isn't it flat at the moment?
wng691s clubby
Member #: 9252
Cleethorpes
to be honest i dont 100 percent know what im looking for but i have now been reasured that it will be fine the way it is
You cannot determine how much to remove unless you've looked at it *happy*
wng691s clubby
Member #: 9252
Cleethorpes
i understand it now Vegard after reading the mini mania thread but i still dont have a pillar drill or such like to test it.
benjamin
Member #: 621
nsw austalia
i just use a small drill bit to see how flat it is , then have the posts machined as nessesary
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
