| Home > General Chat > OT ;mondeo tdci - what to look out for? | |||||||
24th Feb, 2012 at 10:31:39am
Guys
24th Feb, 2012 at 11:12:54am
Dual mass flywheel, starter motor - these are linked, usually the first symptom of the flywheel failing is that the starter motor stops working, due to getting full of the broken up bit of the duel mass flywheel. Listen for any knocking/rattling esp at idle. Look for a shiny starter, or any mention of a new starter in the service history info.
Edited by Tom Fenton on 24th Feb, 2012.
24th Feb, 2012 at 01:17:34pm
White smoke on start. Flashing glowplug light , indicates fucked pump/injectors/bent conrods.. I just replaced all 4 injectors pump and 4rods on my 55 plate... Pump breaks up ,fills injectors with swarf, they stick open and hydraulic the engine :) only external clues are white smoke on cold start and a rough idle.
Edited by evolotion on 24th Feb, 2012. turbo 16v k-series 11.9@118.9 :)
![]() 580 Posts Member #: 9580 Post Whore Surrey |
24th Feb, 2012 at 02:37:35pm
Clutch on air con pump which drives the altenator. Exhaust back box. constant pulling to the left (suspension geometry issue). Crap radio reception. FORD badge on the front (Fix Or Repair Daily). |
24th Feb, 2012 at 06:07:14pm
On 24th Feb, 2012 shellspeed said:
Clutch on air con pump which drives the altenator. Exhaust back box. constant pulling to the left (suspension geometry issue). Crap radio reception. FORD badge on the front (Fix Or Repair Daily). pulling to the left is subframe jigging issue, easily fixed with the correct locking pins, current vauxhall vectra and honda accord suffer the same after a clutch/gearbox/dmf change. turbo 16v k-series 11.9@118.9 :)
24th Feb, 2012 at 06:28:05pm
cheers guys ; i'm going to pass on it; engine was missing and sounded like a handfull of snanners rattling round in a metal bin on start up.
Edited by Rob Gavin on 25th Feb, 2012. |
24th Feb, 2012 at 06:39:43pm
Trouble with an 02 is it has the earlier engine, like mine.
78 Posts Member #: 6322 Advanced Member Bawdeswell, Norfolk |
24th Feb, 2012 at 06:57:07pm
Ours has just had its clutch/flywheel done... On 147K miles! It was owned from new by my father in law and was used gently for 100mile + everyday.
24th Feb, 2012 at 07:47:08pm
Forgot about the injector sticking open. That was under warranty thank god. Tok them 4 days to identify. They fitted a new pump because there was no fuel pressure then wanted to take it back of before I could have the car back. Also needed rear bushes at a similar mileage. I never found it the most comfortable car to drive but the 6 speed 130bhp pulled like a bastard. Wish I kept the pudg 406 |
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
24th Feb, 2012 at 08:14:50pm
V belt tensioners vibrating on idle, they are a pig to change too. engine so close to the body I had to cut down an allen key to undo the top bolt. I've done a few front springs too. usually break, wind down the shocker and cut a nice groove into the inner sidewall. Oh and the bonnet release mechanisms. On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
24th Feb, 2012 at 09:11:22pm
i have one
My build thread..
96 Posts Member #: 9387 Advanced Member Sleaford, Lincolnshire |
25th Feb, 2012 at 01:28:52pm
I am about to sell my 04 2.0TDCI Ghia, its the auto version, tiptronic I think they call it with the option to shift manually on the stick or steering wheel. car has done 185K but well looked after and still drives like new. Its the 130bhp version and goes like stink. Slightly less mpg than the manual. few scrtches and one or two minor faults if you are interested can message with more details www.jb-fab.com www.facebook.com/jbfabrication
25th Feb, 2012 at 08:59:46pm
On 24th Feb, 2012 Rod S said:
The VNT turbo failed on mine too although this mainly happens on later models with the electronic actuator - but it didn't stop my one from pretending it was the newer type..... . I can repair the newer type actuators, done 3 to date, there not even available separately from ford, you have to buy a complete turbo! A wise move rob, i absolutely love mine to drive, but if you get a bad un your in for a world of pain! i bought mine for buttons as a non runner so knew what i was getting into. turbo 16v k-series 11.9@118.9 :)
![]() 825 Posts Member #: 2208 Post Whore Essex |
26th Feb, 2012 at 05:03:20am
mines petrol but ive got the duelmass flywheel and since ive had it off ive had nothing but problems. lost count of clutches ive had in a year. (not through ford, privet garage)
