Home > Help Needed / General Tech Chat > Coated Turbo?
Dr. jinG
Member #: 368
Roseville, CA (USA)
I expect I'll be using some sort of turbo insulation wrap on my set-up, but have heard of businesses that tear down turbos and coat the hot bits with ceramic. It's supposed to help with keeping the heat in the unit (helping a little with power) as well as increase the life of the unit.
Anyone done this and willing to share their experience?
1967 Cooper 's' Turbo build @ www.drjing.com
Johnny
Member #: 6926
Accrington
i thought you should only ceramic coat Naturally aspirated (NA) engines exhausts to keep it warm, as the turbo gets too hot so ideally you dont want a lot of heat?
Thats what i think.
Edited by Johnny on 28th Feb, 2012.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
The compturbo turbo i have here is coated. Will not be able to let you know how it performs in a while though
No, the coating is fine for use on turbo engines and turbos, it keeps the heat energy in the manifold (where you want it) and the heat out of the engine bay (where you don't)
There was an advert in Track car magazine this week for manifold and turbo coatings. £250 ish for a manifold and £150ish for a turbine iirc.
Thats what i think.
Am I right is saying exhaust wrap and a turbo blanket would do the same job?
Yes John.
Rickus
Member #: 9709
Cirencester, glos
The turbo blankets look quite large for the t3 turbo is there enough clearance to fit one in a mini?
Johnny
Member #: 6926
Accrington
Ah right. I understand now. I guess I'll heat wrap my manifold then. Thank you
Dr. jinG
Member #: 368
Roseville, CA (USA)
I would say similar, but not same. The ceramic will insulate the metal as well as the area around the turbo/manifold. With a blanket/wrap, you have no insulation for the internal bits. So, they get full 'benefit' of high heat and moisture (i.e., not good). Blankets and wrap can also hold moisture against external metal parts, hastening their decline.
I look forward to hearing about your experiences, miniminor63.
jamie@thefatgarage
Member #: 9345
Sheffield
As the turbo and manifold (hence blanket/wrap) are at several hundred degrees at engine shutdown and under a bonnet where does the moisture come from?
I have several cars and a quad with wrapped exhausts and no matter how wet they get while driving they are bone dry once the engine is cool. Unless it is then made wet again somehow it will remain dry.
Advantage
Member #: 1450
Near Paris - France
How about polishing the turbine internals ?
Wouldn't it achieve the same goal (maybe in a less efficient way) for free ?
Rusty by nature
Dr. jinG
Member #: 368
Roseville, CA (USA)
Moisture is a natural byproduct of combustion, so internals are subjected to it. Any moisture that gets past the wrap/blanket will turn to steam upon contact, but that steam can be held against the metal longer than having nothing over it (like holding a towel over your head as you steam your sinuses). It wouldn't be a long period of exposure, to be sure, but it's longer than ceramic coating (no exposure where coated) or bare metal.
