Home > Help Needed / General Tech Chat > exhaust down pipe
colas
Member #: 102
Pennsylvania USA
Hey
How do you guys fasten your down pipe to the gearbox. Any pictures would be great.
I just use a made-up plate similar to what the metro had - it mounts to the gearbox using the two lower rear bolts that hold the (clutch side) diff cover in place. I then bolted an exhaust clamp to this plate, around the downpipe (again, like the metro). Works a treat!
I can't get any pics for around a week or so unfortunately...
Forgot to say - many don't even bother with the lower clamp, but as mine has the pleasure of pot-holes and parking humps, it seemed like a good idea...
Edited by turbodave16v on 3rd May, 2005.
turbo hogster
Member #: 178
stowmaket suffolk
and it stops ity blowing.
i used the original gearbox bracket, then bolted a piece of steel to the bracket then welded it to the down pipe. bit like you do for a lcb
colas
Member #: 102
Pennsylvania USA
Thanks guys. thats why I want it on to stop it blowing at the turbo
