Home > Help Needed / General Tech Chat > Camber?
Chalkie
Member #: 9764
Northamptonshire.
1.5 Camber set up fixed front and rear on 10" wheels will this be a bad idea or will it be fine to do? won't get major tyre wear will I? I want the back sorting for sure as mine cambers in one side loads and other side a bit
Thanks
Stephen
(Kit I'm looking at getting is)
http://www.minisport.com/mini-spare-parts/info_SUSKIT7B.html
blister
Member #: 2590
Croydon
no major wear untill 2.0's
Chalkie
Member #: 9764
Northamptonshire.
so for every day use 1.5 will be fine ?
I would say for everyday use 1.5 is too much. I've never used anything other than the standard bottom arms on a daily.
Remember the +1.5 is just that. +1.5 fom where you start from. You may find you crrently have positive camber.
Personally I'd spend the extra on this kit http://www.minispares.com/Product.aspx?ty=...id=38488&title= and then you can set the suspension correctly. Even on 10s I keep camber between -0.5 and -1 for everyday use.
I sent my rear brackets to Carl who made them adjustable. That way I knew they would fit.
I did buy a set like shown in the pic but they weren't even close to lining up and I think they were made from butter.
As for fronts I went with the minispares adjustable bottom arms and minisport on car adjustable "group a" I think they call them tie rods.
Chalkie
Member #: 9764
Northamptonshire.
so be better off going with Minispares set then?
its the rear im most worrid about
