Home > General Chat > Plastic Window Drawings UPDATED
Ben H
Member #: 184
Melton Mowbray, Pie Country
I have just completed my drawings of all the mini glass so that I can can print out templates for cutting my plastic windows out.
Now I am not saying that the drawings are perfect (the front screen is yet to be properly put to the test, and the rear quarters are sized to fit the frame and not fit in a seal). However, I am happy to share my work and put a copy of the drawings up. My question is what format would people like. It is in Autocad, but it can easily be converted to PDF, which I guess will suit more people.
If you want to use these you will need an A0 printer by the way.
Anyway, if you have a format you might like let me know and I will upload the files to somewhere.
Ben
Here are the files. (once again, I am happy to use these my self, but make sure you are happy with them before cutting your plastic into scrap, I take no responsibility for the accuracy of these drawings)
UPDATE. The PDF version was converted to the wrong scale (about 4% small) any file downloaded before today (16/04/12) should be discarded.
http://www.twin-turbo.co.uk/miniwindows/Mi...indow%20PDF.zip
http://www.twin-turbo.co.uk/miniwindows/Mi...0Production.dwg
http://www.twin-turbo.co.uk/miniwindows/Mi...0Production.dxf
Edited by Ben H on 16th Apr, 2012.
Johnny
Member #: 6926
Accrington
upload it in both? i use autocad2000
PDF would be good
Wile E. Coyote
Member #: 7893
Portsmouth
Just be careful when printing at A0 with PDF version that the scaling is spot on.
If anyone wanted a set I wouldn't mind printing out a few for people, have access to A0 printer but couldn't do no more than like 5 people really.
Jamie.
Ben H
Member #: 184
OK, I'll put autocad and PDF up. I have just realised that I have left the drawing in the office, so it will be Monday before I get it done.
Wile E. Coyote
Member #: 7893
Portsmouth
Cool ok, well if 5 people wanna get there names down for some scale copies on here I don't mind doing the sets for people if they cover postage. :)
Jamie.
jamestar
Member #: 9159
Devon
I'll be up for that, put my name down :)
Sam
Member #: 1686
Oxford
Could you post up the dwg file too?
OMG Robert that's a big one
998-city-rat
Member #: 9421
Bardwell, suffolk
I'll take a set of scaled copies Please jamie, cheers Ben for doing this
Jason G
Member #: 1459
En-suite user
Braintree, Essex
DXF is problably the best format. Most companys use this for their G-Coding programs to cut.
On 19th Jan, 2010 wil_h said:
Wile E. Coyote
Member #: 7893
Portsmouth
No worries guys.
Jamie.
Ben H
Member #: 184
Right I have uploaded the drawings in PDF (zip), DWG and DXF. Let me know if you want another format and I will see if I can be arsed to do it.
I have put the links in the first post for future search ease.
Oh and by the way this is where I got my polycarbonate from:
http://www.theonestopplasticsshop.co.uk/
Edited by Ben H on 5th Mar, 2012.
Wile E. Coyote
Member #: 7893
Portsmouth
Thanks a lot Ben :)
Jamie.
Wile E. Coyote
Member #: 7893
Portsmouth
For the 5 with dibs on copies give me a PM.
Jamie.
jamestar
Member #: 9159
Devon
Thanks for sharing Ben and pm'd you Jamie!
topcat
Member #: 9408
Tiptree, Essex
Thanks very much for sharing! I won't hold anyone responsible etc but what were they drawn to fit? I.e. you said rear quarters were over size to fit the frame directly (to bond or rivet in), is the rear the same or made to fit into a rubber?
Thanks,
TC
www.topcatcustom.co.uk
Front and rear screens are to be fitted with rubbers.
topcat
Member #: 9408
Tiptree, Essex
Cool, and the door windows just fit inside the frame and rivet to the top of the door skin?
Door windows are the same size as normal door glass. We have just attached to the top of the door skin, yes.
