| Home > Help Needed / General Tech Chat > Pulling.. | |||||||
![]() 883 Posts Member #: 9774 Post Whore Buckinghamshire |
10th Mar, 2012 at 08:28:45pm
I've had a problem with the car since I bought it, I'm that it is pulling to the right. I've had it tracked, twice, but that didn't help, I then had a problem where it felt like the steering rack had work down, the wheel would turn about 30 degrees either way, there'd be a clunk and then the steering would work.
http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
10th Mar, 2012 at 08:37:33pm
There are a few things that need checking. the most important thing is the spline on the bottom of the steering column. If you have fitted a lowering bracket without loosening the 'U' bolts you put stress on the spline. This then wears and you end up with a very dangerous situation.
10th Mar, 2012 at 09:23:34pm
If it pulls under normal driving i'd be looking at the car crabbing, the toe all over the place (you've had that looked at) the brakes, and the tie rods. If it only pulls under braking I'd check the tie rods.
10th Mar, 2012 at 09:45:34pm
Crabbing or toe settings will never cause a car to pull in one direction consistantly. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Mar, 2012 at 10:05:15pm
Are you sure? My car pulled to the left for a while, went and had my toe reset, came out fine. Managed to centre my wheel too when they sorted it. On 26th Jan, 2012 Tom Fenton said:
10th Mar, 2012 at 10:18:19pm
Thanks for the reply's guys,
10th Mar, 2012 at 10:25:35pm
On 10th Mar, 2012 Mike-998 said:
wheel would turn about 30 degrees either way, there'd be a clunk and then the steering would work. Steering column worn out at the bottom. Do not drive the car until this is repaired.
10th Mar, 2012 at 10:46:59pm
Sorry, should have said, that was a few months ago, steering column has since been replaced http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
10th Mar, 2012 at 11:28:36pm
Could be siezed calipers. Try some brake fluid around the seals on the pistons after cleaning them up if they don't push in relatively easily. I had to use a big bar against the old discs the other day, to free and move the pistons in enough to fit a new disc and pads. Couldnt push them back firmly with my hand or a screwdriver like you should be able to. Edited by Carlzilla on 10th Mar, 2012. On 26th Jan, 2012 Tom Fenton said:
11th Mar, 2012 at 07:59:20am
Check the U bolts on the rack are tight - this would allow the rack to move around.
11th Mar, 2012 at 09:50:39am
You need to check the column spline.
Sorry, should have said, that was a few months ago, steering column has since been replaced If you think about it, the toe will always centre its self, so is unlikely to result in puppling consistantly to one side. If it was massively to out it may be more susceptible to pulling to the left owing to the camber of the road. On 10th Mar, 2012 Carlzilla said:
Are you sure? My car pulled to the left for a while, went and had my toe reset, came out fine. Managed to centre my wheel too when they sorted it. Edited by wil_h on 11th Mar, 2012. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
11th Mar, 2012 at 01:32:38pm
I know what you're saying and it makes perfect sense, but it did make a massive difference to the pulling to one side. And the life of the inside of the tyres! But that was not long after I bought my car, it was nothing to do with me haha. I normally centre the wheel, and get the wheels something like straight, even them up front to back with a tape measure then take the car to be properly aligned whenever i have messed with the track rod ends. On 26th Jan, 2012 Tom Fenton said:
11th Mar, 2012 at 06:23:08pm
I'd forgotten about that bit, just about to go and lift the car up and have a look around, but Carl has reminded me about my tyres, which are wearing unbelievably fast on the inside, I've done about 1000 miles on these two and they're almost finished...
11th Mar, 2012 at 06:53:52pm
Go drop a tape measure between the front rim lips on the inside, between the front at 3 and 9 o clock. It'll tell you if your toe is out. Should be pretty even measurements. Tyre wear is a bastard on small wheels if the toe is miles out, it wears them out in no time. On 26th Jan, 2012 Tom Fenton said:
11th Mar, 2012 at 09:21:31pm
What Andy said, check the U bolts that hold the rack in. Mine came loose and caused me no end of torque steer issues!
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
11th Mar, 2012 at 11:02:53pm
If there is a clunking noise at the steering, does sound like U bolts not tight, like Andy and Matt says, I've had this happen to me in the past.. Main Build
12th Mar, 2012 at 07:30:37am
Mine pulls to the left. I changed out the bottom arm bushes that were way past their best yesterday - it made a difference to acceleration pull but the car still goes left when you let go of the wheel.
12th Mar, 2012 at 10:06:35am
Just had a look under the car, there didn't seem to be any play in anything there, it didn't look like it had been changed recently, but it also didn't look like it was about to fall apart.
Edited by Mike-998 on 12th Mar, 2012. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
12th Mar, 2012 at 10:42:50am
Uh oh. Looks like a weepy crank oil seal. If something is worth doing, it's worth doing half of. |
12th Mar, 2012 at 10:53:43am
On 12th Mar, 2012 Mike-998 said:
I've also manage to find a pretty serious oil leak, which is hopefully the cause of my low oil pressure] Nope sorry. Oil pressure being low is down to worn pump/crank bearings.
12th Mar, 2012 at 10:58:06am
I was hoping I wasn't going to have to do any serious work on the engine, but never mind, I'd rather that than i fit the turbo and blow the thing up..
12th Mar, 2012 at 11:03:50am
They aren't that difficult. Get the haynes manual out. If something is worth doing, it's worth doing half of. |
12th Mar, 2012 at 11:06:21am
Really? The main obstacle I have is that i have no way of taking the engine out at the moment.. http://www.turbominis.co.uk/forums/index.p...tid=469104&fr=0 |
12th Mar, 2012 at 11:37:03am
Spend some money on a hoist or rent one. If something is worth doing, it's worth doing half of. |
12th Mar, 2012 at 11:49:44am
Look like nows the time to to whip the engine out and strip the subframe and suspension down for a good refurb. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
