| Home > Help Needed / General Tech Chat > Moving front bump stop location | |||||||
318 Posts Member #: 9408 Senior Member Tiptree, Essex |
13th Mar, 2012 at 07:13:10pm
Hi, nothing too dramatic but was wondering if it was possible to cut the bump stop mounts off the turrets, and re-welding them on just a little bit further up, so you get more travel on the front suspension but still retain proper bump stops.
www.topcatcustom.co.uk |
13th Mar, 2012 at 07:52:24pm
there bolted on? just un bolt ( i admit its fiddly) and re-drill
Edited by Brett on 13th Mar, 2012. Yes i moved to the darkside |
![]() 871 Posts Member #: 2590 Post Whore Croydon |
13th Mar, 2012 at 08:02:00pm
i know it isnt the best bet with things like this but i just hack sawed a bit off the top of the bump stop itself |
13th Mar, 2012 at 08:10:07pm
i got the angle grinder on mine and took off all but 10mm or so, Yes i moved to the darkside |
13th Mar, 2012 at 09:40:29pm
We have totally removed the stops and cut out the mounting on the subframe. However this is a race car and runs St if springs. You some stops on a road car or rally car, IMO. http://www.twin-turbo.co.uk
13th Mar, 2012 at 09:57:34pm
Can you repeat that in English Ben? On 26th Jan, 2012 Tom Fenton said:
![]() 478 Posts Member #: 9269 Senior Member Rotherham |
13th Mar, 2012 at 10:17:04pm
lol
Craig
13th Mar, 2012 at 11:44:06pm
How does re-drilling the position make the travel any longer? I will probably end up cutting them down (and maybe drilling them to soften them up) but wondered about relocating the actual mounts maybe 1/2" higher up the turret, providing it's still possible to get the rubber cones in behind them!
14th Mar, 2012 at 12:49:34am
On 13th Mar, 2012 Brett said:
there bolted on? just un bolt and re-drill On 13th Mar, 2012 topcat said: i dont see any difference
cut the bump stop mounts off the turrets, and re-welding them on Edited by Brett on 14th Mar, 2012. Yes i moved to the darkside |
14th Mar, 2012 at 08:04:31am
On 13th Mar, 2012 Carlzilla said:
Can you repeat that in English Ben? ![]() http://www.twin-turbo.co.uk
14th Mar, 2012 at 08:41:45am
I think that the only sensible solution is shorter bumpstops, or bumpstops on the damper.
14th Mar, 2012 at 09:41:16am
Brett- you must be thinking of something else, this shows what I am proposing, the blue line is the original bump stop mount, and I am suggesting cut it out, and move it up to where the red line is, giving more travel. I'm not sure how drilling any holes would do the same thing?
14th Mar, 2012 at 09:53:38am
Two words - driveshaft angle! Especially if you are contemplating rallying! On 5th Sep, 2011 Vegard said:
14th Mar, 2012 at 09:54:44am
I can't see a problem with doing what you're suggesting. You're basically just increasing the travel before it hits the stop but retauning a lower ride height.
Edited by matty on 14th Mar, 2012. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Mar, 2012 at 10:10:53am
Not sure that this is relavent. I mistakenly thought that he was wanting to move the bump stop to enable the car to be lowered. This is not the case, it's just to allow more movement, which you will get with the springs rather than rubber doughnuts.
On 14th Mar, 2012 Scruffy said:
Two words - driveshaft angle! Especially if you are contemplating rallying! From that photo, it seems a reasonable suggestion, I presume that you run it quite high anyway? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
14th Mar, 2012 at 11:12:51am
Why would you need longer travel than the standard setup give? On 13th Jul, 2012 Ben H said:
14th Mar, 2012 at 05:43:07pm
My bump stops had a thick metal washer kind of thing underneath them, I unscrewed them & removed it. So I still had the full bumpstop, but it was lower.
14th Mar, 2012 at 06:09:49pm
yep sorry ive read it as your cutting the bump stops off the turrets to move them didnt realise you mean cut the turrets to raise the bump stops Yes i moved to the darkside |
14th Mar, 2012 at 07:01:51pm
Lol no worries! Thanks for the input- I should have added that is NOT my picture, just a google theft!
