Home > Show Us Yours! > DJ Wilma's VVC 1275GT Mini (that may get a k series turbo)
djwilma
Member #: 9836
Bournemouth
Picked it up on the weekend, will be stripping it this week and seeing whats what. Basically it will need a lot of welding, but all the bits are there and my mate Cheeky Scott (who sprayed my metro) is mini mad and will do the body work / spraying here in Bournemouth
Its not an original colour its like a duck pond green, we are thinking it was originally denim blue but we will see.
Has a metro loom for the engine and a metro fuse box and interior loom with metro clocks
Looks like this on the back of a truck
There is also talk of junking the 160vvc (which has a MEMS2 loom, inlet and manifold due to me having this left over from my metro vvc), we have a Rover 100 Ascot that could take this, and putting a 1.8 turbo in with an emerald and shooting for 220bhp but will need a PG1 and quaife diff for that
Turbo'ing the rover k series since 2010 *wink*
shellspeed
Member #: 9580
Surrey
I cut the front of that and fitted the subframe about 4 years ago! He didn't finish it then!
djwilma
Member #: 9836
Bournemouth
nope its been sat in his garden since he bought it from you !
Wont be long till its finished though, did you do the steering column, loom and frame too ?
shellspeed
Member #: 9580
Surrey
Will owned the car then too, nothing to do with me. If I remember correctly I helped drill some of the holes and drop the engine in. Will did the steering himself.
djwilma
Member #: 9836
Bournemouth
will sold it on to a lad in basingstoke, 2 years ago.....and its been in his garden since
hazpalmer
Member #: 9038
Carlisle, Cumbria
i remember will having this car and then he sold it on, and i remember it needed quite a bit of welding doing
djwilma
Member #: 9836
Bournemouth
Still does, will be taking it back to basics and rebuilding it up and painting it in the original denim blue
djwilma
Member #: 9836
Bournemouth
Took the engine out today and cleaned the engine bay out
R65U wants to be changed to a PG1 with torsen, but as yet havent found one. Should have the front back to metal soon clean up the crap welding and get it sprayed so i can fit the engine
Need to change the SPI tank fuel pump to the VVC one i took out the tro, feed some pipes front to back and hook up the front brakes before the engine fitting
Going to take the 185 55 13 Toyo road pros off the GTA wheels and fit them to my MPI's for the metro
Need ideas on what wheels to fit so it doesnt look like a mini on metro wheels. Will run 175 50 13's too
Have no ide a
djwilma
Member #: 9836
Bournemouth
with pics *wink*
If you want the best wheels, click the banner at the top...
djwilma
Member #: 9836
Bournemouth
i may get them to make some up for my metro so i can get bigger brakes in but have bought some steelies today
djwilma
Member #: 9836
Bournemouth
Few things changed, i bought a PG1 with a torsen diff so going to change out the R65U as the car will be tracked and looking at 1/4 mile times the diff cars are 0.5 quicker in the late 13s
Also removed the cross spoke alloys and stole the near new Toyo Roadpro 185 55 13s and put them on the metro
So had to fit my Avon ZZRs which look ok, my mate says it looks like a mini on a metro chassis but will collect steelies from Tony Itsonlyme on thursday, along with MGF Calipers, carriers, 160 6 bolt manifold and MGF shafts for the PG1. I have some spare discs and pads (chocolate green stuff) for the time being
Spacers on the back look er fooking big
Subframe is new with braided lines for the brakes with spax shocks *wink*
Chalkie
Member #: 9764
Northamptonshire.
Wouldn't it been easier to put a T Series engine in it :)?
djwilma
Member #: 9836
Bournemouth
yes if i didnt want to go round corners
T series are lovely engines and very tuneable, but way way to heavy for a mini unless it was mid engined
Also they wont fit the subframe as the water pump fouls, could fit an electric one though
But not after a drag racer just something to scare people with
Chalkie
Member #: 9764
Northamptonshire.
oh right fair enough :) How you dropping the CR on the K series? Decompression Plate or Shorter Conrods?
djwilma
Member #: 9836
Bournemouth
gonna stick with the 160 vvc on this one
But with the metro it has shorter con rods, or you can use the 1.8 Turbo k series bottom end
djwilma
Member #: 9836
Bournemouth
Oh well looks like a trip to Santa Pod and being beaten by a 1.8 turbo metro has made me realise my mini needs a turbo !
So we have bought a 75 Turbo with a blown head gasket for £450, will be getting the help of the ever helpful itsonlyme to strip the engine have a loom and ecu from the metro boys will be shooting for 200bhp on the std engine which shouldnt be a problem.
Gearbox from the Metro will be used, as mini has much smaller tyres and will have a type A torsen diff from the 820 turbo box i just bought for the elise
Will get pics up soon
djwilma
Member #: 9836
Bournemouth
Not much has been done as manic busy at work but collected the 75 1.8 Turbo which is now at itsonlyme's having the HGF fixed
Should have the engine soon, can then bolt it in and have a Zandf remapped ecu and loom from the guy i sold my 1.4 to so should be close to the 200bhp mark once the 2 1/2" exhaust has been made with no cat :)
Also had a new pedal made to go around the steering column
Had a K7 gearbox made up by Matt Parker with a Type B that needs to be collected and will be using the metro flywheel and 220 turbo clutch
Also got some 175 50 13 A539 yokos for £150 which are basically brand new......
Bought an oil cooler off ebay from an unknown k series engine, looks like the one fitted to my 160 VVC but should be enough to help keep temps down. Its water cooler and will be plumbed in some how
Engine is still in rover 75 but its getting a new head gasket, water pump, idler cam belt and so on as we speak and will be out next weekend
Built a Steel caged bearing PG1 with K7 Gearset and had a type B Torsen diff fitted too, should be nice on the motorway about 22mph per thousand
Final Drive 3.647
1st 2.923 2nd 1.750 3rd 1.222 4th 0.935 5th 0.765
1st 5.55 per 1000rpm 39mph @ 7000rpm
2nd 9.27 per 1000rpm 65mph @ 7000rpm
3rd 13.28 per 1000rpm 93mph @ 7000rpm
4th 17.35 per 1000rpm 121mph @ 7000rpm
5th 21.21 per 1000rpm 148mph @ 7000rpm
Have finally decided on a colour and its going to be black, wife found out i had bought it and insisted it be black so had the front slam panel sprayed ready for the engine
Fuel pipes have been stolen from an MPI mini, and will be making up the brake pipes soon
3mm spacers fitted to the front and wheels now clear too
