Home > Wanted > where to get a few bits
1976 clubamn
Member #: 400
Shrewsbury
not sure if this is in the correct place but, i need some parts and could do with some advise on where to get them.
1, valve stem oil seals
2, turbo head gasket (standard or uprated version of standard)
3, a decent manifold gasket
i would prefer to get these parts from one supplyer to save on postage so if anyone knows a place i can get them from please let me know asap. thanks guys.
one last thing, i am after a braided oil supply line for the turbo and i need it fast, i did order one from ian but i know he is away now so can anyone help hear?
ben.
If it breaks... build a much faster one
Try Simon @ Morspeed on 01530 830369 and tell him I sent you.
adam1330
Member #: 238
essex
you will get all that in a head gasket set, the payen BK450 is the one to use. any decent motor spares place will have one.
as for the braided oil pipe, try miniwilliams on here, think he sells them.
Nick
Member #: 154
Midlands
if you're after a full head gasket set, which would be easiest. you'll need a Payen DK451. thats the proper turbo headset and you get the proper manifold gasket in it, aswell as al the carb/plenum/turbo gaskets etc.
the BK450 is just a standard 1275 head gasket so if you get a DK450 set then you get the normal manifold gasket.
1976 clubamn
Member #: 400
Shrewsbury
thanks for the help.
