| Home > Technical Chat > My Chamber Shape- Opinions Please | |||||||
265 Posts Member #: 368 Senior Member Roseville, CA (USA) |
8th May, 2005 at 07:34:55pm
I did some head grinding yesterday, and forgot one key step in the process. However, the shape I ended up with seems to be viable. I'm pretty sure I've seen this basic shape on another person's head, so it's not a ground-breaking effort. Aside from the lowered compression, is this a good shape for an A-series turbo for power and detonation prevention, or is TurboPhil's steep angle, kidney shaped, no-beak design vastly superior (his is more the shape I was trying for!)...? **************************************
450 Posts Member #: 449 Senior Member Oxford |
8th May, 2005 at 07:43:26pm
everyone has there own opinons on here about what works but basically give it a go. The main aim is to ruduce compression ratio after that is to make a good shape chamber to reduce detonation. Some do away with the beak and some keep it.
8th May, 2005 at 08:59:00pm
Thank you, Mike. I look forward to seeing your results.
8th May, 2005 at 10:38:32pm
Edited by Tom Fenton on 8th May, 2005.
9th May, 2005 at 01:03:46am
Thank you, Tom! How do you do that? And is there some way that I can make future pics smaller so I don't chew up too much of TurboMinis' bandwidth? **************************************
9th May, 2005 at 06:21:13am
Its quite straightforward, you need to put the letters img in square brackets, then the web address of your picture, and then afterwards put /img again in square brackets. With no spaces between or it won't work.
9th May, 2005 at 04:17:57pm
Thank you, Tom! I'll make sure to do that in the future.
9th May, 2005 at 11:27:35pm
also tape an old or cheap head gasket to the head so if you slip with the grinder you dont damage the head no longer a series, but still 1.3 turbo.
10th May, 2005 at 07:24:24am
And leave some old scrap valves in the guides to protect the seat area as well.
10th May, 2005 at 04:45:20pm
Thanks, guys. I saw the scrap valve technique the other day and thought it a good idea, too!
16th May, 2005 at 07:59:15pm
Just wanted to update you all on my head progress. I've completed the chamber shaping. Here it is: **************************************
