| Home > Help Needed / General Tech Chat > what power will a straight cut box take? | |||||||
39 Posts Member #: 444 Member |
9th May, 2005 at 05:50:28pm
hi guys one for all of you with over 110 at the flywheel |
9th May, 2005 at 06:32:40pm
Torque is the problem with Mini gearboxes, which is why forced induction engines with their large amount of torque at low revs struggle more than high revving NA engines. The problem with the 5 speed boxes is that the 5th gear hangs out on a shaft with no bearing at the other side of it, and so that shaft is prone to flex and the gear moves when a high torque and hence a high gear separation force exists. I have not personally used a 5 speed mini box, but from the adverts and write ups I have seen I have got the impression they are only really suitable for standard injection coopers or very mildly tweeked cars say no more than 85bhp.
9th May, 2005 at 07:41:11pm
if you go for sc drops plus a sccr set with a well rebuilt box and a 4 pin diff then the worlds are your oyster.
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
9th May, 2005 at 07:44:09pm
i'd probably go with a syncro s/c box as its a fair old wack more to get a dog box, and remember buying 2nd hand can be tricky what ever the engagement type
Edited by dan on 9th May, 2005. |
9th May, 2005 at 07:59:55pm
Tom are you sure you’re correct on the JKD 5-speed info?
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
9th May, 2005 at 08:01:56pm
point taken on the 5 speed but not planing on using that gear for acceleration more crusing
Edited by sandfly on 9th May, 2005. |
9th May, 2005 at 08:10:27pm
1450cc 100Bhp @ the wheels if you call that anger.
9th May, 2005 at 08:32:39pm
yeah i call that anger
9th May, 2005 at 09:18:46pm
Maybe it was the Minispares (?) 5 sp box I looked at. I definately remember though that there was poor support at the far end of the 5th gear shaft? And in the catalogue I had it stated that the gearbox was not suitable for tuned engines.
9th May, 2005 at 09:52:19pm
The Box has seen thousands of motorway miles running to London and back from Derbyshire. and a fair few track day miles but i find it very hard to hit 5th on the track.
![]() 1128 Posts Member #: 142 Post Whore Winchester |
9th May, 2005 at 09:53:00pm
i think jk 5 speeds use a brand new casing designed specifically for the job so they may be better. |
9th May, 2005 at 11:06:25pm
mini speed cant even put on an engine steady properly, hogster builds matts gearboxes and a few others enough said! |
9th May, 2005 at 11:17:03pm
10th May, 2005 at 12:34:08am
cheers for all the info lads just wanted to get the know from the people who have actually had this kind of power
10th May, 2005 at 04:30:25pm
how much is the JK SCCR 5speed box now ?
10th May, 2005 at 11:08:21pm
£400 second hand or £2000 new
(plug, plug
