Home > Help Needed / General Tech Chat > diff pre-load/shimming?
Nick
Member #: 154
Midlands
Just a quick one chaps, having a bit of a brain fart and haven't done this for years.
I've just swapped me CW&P so just about to re-shim the diff and can't remeber the numbers properly.
I've got a 20 thou gap, does that mean i need 12 thou worth of shims in there, or do i need 20 thou worth of shims?
I'm running a quaiffe ATB if that makes any difference?
Cheers :)
isnt it your 20 thou gap , plus whatever preload you need ,which depends on what type of bearings you have ?
editted for numptiness.
Edited by robert on 14th Apr, 2012.
Nick
Member #: 154
Midlands
i have no idea chap, my haynes is really old and just says rod change gearboxes are new fangled things so i'm a bit dubious to trust it.
I'm running pot joints and bearing wise i didn't realise there was more than one type :s mine have thrust face or something written on them?
I give it a 1 thou pre load, so with a 20 thou gap Id fit 21 thou of shims
Alex
Member #: 1851
Woolavington, Zummerzet
Don't forget the gasket !
20 thou, plus 1 thou preload, minus compressed gasket thickness = shim thickness.
Nick
Member #: 154
Midlands
Cheers chaps :)
nala56
Member #: 9661
Sheffield South Yorkshire GB.
Surely if you preload it should be minus 1 thou, not plus..
Main Build
Upgrade to Turbo
nala56
Member #: 9661
Hope this helps..
Main Build
Upgrade to Turbo
No, plus. Minus 1 thou would take load off
Also, measure the gasket as they are not at all the same thickness as what the Haynes manual states.
nala56
Member #: 9661
I realised my mistake after the post, that's why I posted the photo I took from the manual, I got it wrong, sorry..
Main Build
Upgrade to Turbo
