| Home > Help Needed / General Tech Chat > Turbo dizzy | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
10th May, 2005 at 12:45:23pm
If I cannot get hold of a MK1/MK2 dizzy what options do I have? Can I use a non-turbo variant or can anybody recommend an aftermarket alternative? |
10th May, 2005 at 01:08:56pm
I ran a welded-up dizzy, set at 25 degrees for years. It's not an ideal set-up bu it works.
10th May, 2005 at 02:18:59pm
Or get any 1275 electonic dizzy, and post it up to RaceSpec (01925 636 959) and get him to modify it to 'turbo' specification... On 17th Nov, 2014 Tom Fenton said:
10th May, 2005 at 02:28:09pm
Turbo dizzys seem to come up second hand quite regularly, keep an eye on ebay. I would guess you won't struggle too much to find one.
10th May, 2005 at 02:29:04pm
That sound's like the easiest/cheapest solution, thanks! |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
10th May, 2005 at 05:35:04pm
daft question: What's the difference between the two? It's not just a different curve is it? |
10th May, 2005 at 06:22:56pm
Nothing ignition wise.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
10th May, 2005 at 08:26:13pm
On 10/05/2005 13:08:56 wil_h said:
A fulll electronic ignition is what you want. Wil Where can I get this and how much ££££ |
10th May, 2005 at 08:40:57pm
mega jolt
10th May, 2005 at 08:41:14pm
emerald
568 Posts Member #: 102 Post Whore Pennsylvania USA |
10th May, 2005 at 10:33:12pm
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...4548217274&rd=1 |
11th May, 2005 at 09:26:47am
Mega Jolt Lite Jr is what you want!!
Edited by AlexF2003 on 11th May, 2005. AlexF |
11th May, 2005 at 09:53:36am
Is it fairly straight forward to map the megajolt jr from a laptop at home?? -MINI CLUBMAN 1380 TURBO- |
![]() 264 Posts Member #: 403 Senior Member sydney Australia |
11th May, 2005 at 11:15:00am
back on the electric metro dizzy's, can you advance them in the same way as a non electric bobweight dizzy? 998 turbo |
11th May, 2005 at 11:17:12am
and could Racespec modify a dizzy to suit my 998cc turbo?
998 turbo |
11th May, 2005 at 11:37:22pm
I expect so they put them on a dizzy dyno and do an advance v rpm curve
12th May, 2005 at 08:24:10am
On 11/05/2005 09:53:36 T3Tone said:
Is it fairly straight forward to map the megajolt jr from a laptop at home?? yep :) start with the std settings from your dizzy and work from there
Alex AlexF |
12th May, 2005 at 09:35:52am
can anyone on here confirm that the elertic dizzy is advancable? im trying to make a decision on what dizzy to buy.
998 turbo |
13th May, 2005 at 04:14:27pm
? 998 turbo |
13th May, 2005 at 04:45:18pm
The electric distributor only uses electrics to trigger the coil. The advance curve is still controlled as a conventional dizzy with bob weights, primary and secondary springs, and the vacuum advance unit.
13th May, 2005 at 04:47:22pm
you just need a stock 1275 electronic dizzy.
14th May, 2005 at 06:59:29am
I have used 42635 dizzy's (ie the latest from cooper, british open, etc )with success, just play on the idle timing until you meet knock and then retard 2/4°, I generally found that 5/6° initial timing , is ok,depend on the boost and cr. |
14th May, 2005 at 07:59:30am
ok, sweet, thanks all
998 turbo |
