Home > Technical Chat > which cylinder melted poll
on your sickly a series , which cylinder/s melted?
if its more than one , just vote twice (if that works , you might have to come out and in again ..er lol)
12 Votes 2 Votes - 11%
25 Votes 5 Votes - 28%
33 Votes 3 Votes - 17%
48 Votes 8 Votes - 44%
Chalkie
Member #: 9764
Northamptonshire.
Well mine didn't melt as such more expolded..
Chalkie
Member #: 9764
Northamptonshire.
Need I say more.
wng691s clubby
Member #: 9252
Cleethorpes
voted
Done now needs redoing lol
If the picture above is genuine, where is the other piston that should be next to it ???
The picture should be 2 & 3 next to each other.
Confused....
Johnny
Member #: 6926
Accrington
that looks like a valve took it out and that the block has been demolished by an angle grinder?
Chalkie
Member #: 9764
Northamptonshire.
Yes I cut the 850 block with an angle grinder and removed the other pistons, the block is in tech terms f**ked
jlay
Member #: 1742
essex
number 4
My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901
Mr Joshua
Member #: 1954
Luton Bedfordshire
Done two and four and cracked the head. You could see the full width of the top ring in some areas.
Own the day
That must have been a massive crack in the head of you could see the top rings
turbominivanman
Member #: 1504
Westbury, Wiltshire
No 4 Robert. Have voted.
Rich.
thanks rich ,looking like no4 is the fave .
Makes sense. Hottest of the two leaner cylinders.
Any chance that the poll result could be made visible to us that cannot vote?
Edited by Paul S on 6th May, 2012.
look at the topic when not logged in *wink*
