Home > Help Needed / General Tech Chat > top arm rubber seals
jamz
Member #: 2292
Tool
Herne Bay, kent
i rebuilt my top arms last year and remembered i lost of the little rubber bits that sit on the inside either end. do i NEED this on a race/track only car that will be rebuilt alot? or can i leave them out?
cheers
james
cant beat a good blowout.
Good question. I'd fit them but if they're really needed or not if you constantly keep them greased up....??
jamz
Member #: 2292
Tool
Herne Bay, kent
they are such a pain when fitting the tops arms back in lol. and im not sure if can buy them on there own. the grease wont come out. as its still tight against the metal just will be needed to kept clean
jamz
Member #: 2292
Tool
Herne Bay, kent
does any of the racers know?
nala56
Member #: 9661
Sheffield South Yorkshire GB.
You can buy those rubber seals, I've just bought some for the radius arms, there the same seals as the front upper arms, Mini spares is where you will get them 74 pence each..
Main Build
Upgrade to Turbo
jamz
Member #: 2292
Tool
Herne Bay, kent
thanks for letting me know i can get them :)
anyone know if i NEED them though. as they are ap ain in the arse haha
adam1330
Member #: 238
essex
You probably don't need to use them, It's a personal choice, either keep dirt and grit away or take a chance of getting dirt and grit into the bearings etc...I guess as long as they are kept greased up you will be a bit safer.
Yo-Han
Member #: 3228
North of the Netherlands
A bodge but since it's just for the track:
Can't you cut one open, then peal it over the shaft and hold it with a wide tie-wrap or hose clamp?
Dazed and Confused....
Jimmyful
Member #: 9865
I threw mine in the bin thinking my polyflex kit would come with them.
I had to raid past 3 days worth of food and cat crap to get them back. Found them tho.
nala56
Member #: 9661
There easy to put on if you pull the rubber seal right on to the casting, the one at the shaft entry end, and when the shaft is in you just slide the rubber seal back into place, job done..
PS.. They keep the grease in, and the dirt out..
Edited by nala56 on 22nd Apr, 2012.
Main Build
Upgrade to Turbo
