| Home > Help Needed / General Tech Chat > another Smiths Rev counter question! | |||||||
113 Posts Member #: 9241 Advanced Member Edinburgh / Dumfries |
23rd Apr, 2012 at 10:17:50am
Hi all - Looking for some help as I can't get my head around my rev counter wiring!
Edited by wagon_rider on 23rd Apr, 2012. |
![]() 580 Posts Member #: 9580 Post Whore Surrey |
23rd Apr, 2012 at 10:35:25am
Electronic ignition dizzy from a metro with a points only rev counter will do that. |
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
23rd Apr, 2012 at 10:54:16am
What sort of Smiths tach is it ?
Metric is for people who can't do fractions. |
23rd Apr, 2012 at 10:59:23am
On 23rd Apr, 2012 shellspeed said:
Electronic ignition dizzy from a metro with a points only rev counter will do that. Can you tell if its a Metro dizzy? Alex - I'm afraid I don't have a good pic, think it was an MGB or something
oh here's a better one
23rd Apr, 2012 at 11:43:04am
black box on side of dizzy means its electronic type. You need an RVC type tacho which yours does appear to be so it may well be buggered. RVI tacho's only work with points systems. Also found this which may be of use http://www.gomog.com/allmorgan/smithsclassic.html
23rd Apr, 2012 at 11:54:07am
My Smiths tach goes to negative on the coil - not positive I seriously doubt it! |
23rd Apr, 2012 at 01:18:22pm
You need an RVC type tacho which yours does appear to be so it may well be buggered. So the Tach should work with that dizzy then? It does appear to have RCV written on it.
black box on side of dizzy means its electronic type. Found this other pic which I guess will confirm its a metro dizzy. I thought it looked different from all the other dizzy I'd seen on my old minis.
Thank you for the advice I appreciate it. Not sure what to do now! These stupid gauges have been so much more hassle & expense then they where worth!
At least if I switch to mega jolt it should work? Do I need the wee black "thingy"? Edited by wagon_rider on 23rd Apr, 2012. |
23rd Apr, 2012 at 01:29:35pm
Pauls got a point. Having just re-read the whole thing again it appears you have a few things about face.
23rd Apr, 2012 at 01:39:49pm
On 23rd Apr, 2012 wagon_rider said:
I'm sure that the terminal (2) is the -ve that's where the tach (3) was fed from. Maybe I'll take the tach off and re wire it with a direct feed from the battery and see if that helps. Maybe I got something else wrong in my loom :( Thanks for the info on the suppressor. I don't have a radio so I can loose it :) |
288 Posts Member #: 6267 Senior Member Bristol |
23rd Apr, 2012 at 07:25:02pm
That is a RVC type rev counter as fitted to a 72-74 MGB and should be wired to the negative side of the coil.
![]() 825 Posts Member #: 2208 Post Whore Essex |
23rd Apr, 2012 at 10:22:43pm
did you fit your own light in these? |
24th Apr, 2012 at 07:39:51am
http://mk1-forum.net/viewtopic.php?f=3&t=3...s+wiring#p22799 On 13th Jul, 2012 Ben H said:
24th Apr, 2012 at 10:23:26am
Thanks Flame Red.
On 23rd Apr, 2012 wintersurferuk said:
did you fit your own light in these? The back light? Yes. 3 white LEDS Thanks for the link Vegard - Will have a read :) |
