| Home > Help Needed / General Tech Chat > MISSING | |||||||
216 Posts Member #: 370 Reads "my mates" max power whilst wearing my Mrs's underwear |
11th May, 2005 at 01:33:17pm
recently finnished my motor and it has never run tidy, its missing and spluttering when pulling off under low revs, also miss's from time to time when traveling at speed, it sorta struggles then all the sudden comes back to live ..... |
11th May, 2005 at 01:40:16pm
sounds like the coil to me |
11th May, 2005 at 02:25:33pm
It could be one of about a hundred things. Start working through, I would check the plugs for a start.
11th May, 2005 at 03:45:00pm
i've done the following,
11th May, 2005 at 04:19:15pm
Check the coil and module out. The Metro haynes has a detailed procedure giving you winding resistances etc to check.
421 Posts Member #: 245 Senior Member |
11th May, 2005 at 05:13:20pm
might be running a bit lean, |
11th May, 2005 at 05:39:08pm
just a thought steve
11th May, 2005 at 08:18:00pm
nope not done the t-peice trick will look into this , i didnt get the time today to look at it, im gonna have a go first thing in the morning, thanks for the replys guys,
Edited by turbosteve on 11th May, 2005. |
15th May, 2005 at 04:55:06pm
you wont believe this ....
15th May, 2005 at 05:02:18pm
oops |
