Home > Help Needed / General Tech Chat > Weight saving - How structural is the rear bulkhead and parcel shelf? what have people done?
JetBLICK
Member #: 1261
Droitwich
What have people done in this area then? Your all weight saving nuts.. thers a lot of weight in that panel.
Theres a lot of shape there too, so im wandering how structural it is? Im thinking along the lines of cutting out the main part of the panel and riviting in an aluminium or carbon panel in its place?
im sure some guys on here have tackled this area, what have you guys done?
Dan
Leave it alone mate
there is a detailed thread some where, quite recent too, basically what Paul says its a very structural part where stiffness/ chassis twist is concerned
Basically, by trying to save weight there, you'll end up adding more weight than there originally was in bracing/rollcage. So most people just leave it well alone.
As said above ^^^^
You'll probably safe a similar amount of weight by just removing the rear seat belt mounts. These weigh about 500g each and won't effect the structure.
JetBLICK
Member #: 1261
Droitwich
ah k.. I am getting the cage welded to the shell and was just a thought, as the panel is only actually attached at the top and the bottom
wheres this thread then? what was it call?.. i did do a search but didnt come up with anything
spaceframemini has had a seat back made from ALU, but he has a big cage tied into the shell.
1380rich
Member #: 9766
Warwickshire
If you have a full weld in cage to the shock mounts I don't see a problem with removing it. Mines gone but I already had a cage
Avon 2010 class c 3rd
D4VE
Member #: 10749
lowestoft suffolk
I have searched as much as i can on this.. tonnes of
"" do it...
Dont do it...
Ive done it... ""
But i thought id ask the question.... hows it any different to a van/estate/traveller ?
Edited by D4VE on 12th Jan, 2019.
Nothing gets past Dave lol
tadge44
Member #: 2500
Buckinghamshire
And how stiff are they in torsion, by comparison ?
monsterob
Member #: 11029
Crewe
would the roof on the estate with its ribs not compensate vs the std mini roof. I need to put some structure into my estate but this is to mount rear belts for the 3 bin lids, or im going to have to fit isofix .........
Outside the box
D4VE
Member #: 10749
lowestoft suffolk
Not all of them have ribbed roofs...
AWDmoke
Member #: 713
Western Australia
Structural rigidity and vans do not belong in the same sentence.
The amount of flex in the rear of my 73 van was scary.
On 24th Dec, 2008 Nic said:
D4VE
Member #: 10749
lowestoft suffolk
This is my point?
tadge44
Member #: 2500
Buckinghamshire
And mine !!
