| Home > Help Needed / General Tech Chat > few paint questions | |||||||
![]() 673 Posts Member #: 1395 Post Whore chepstow |
1st May, 2012 at 04:53:09pm
What do people use to treat surface rust?
1st May, 2012 at 04:58:03pm
I'm etching, seam sealer and stone chip under mine. Then it will be getting colour over the top of that. On 11th Feb, 2015 robert said:
1st May, 2012 at 05:01:55pm
aerosol stonechip? or from a gun |
1st May, 2012 at 05:05:00pm
Aerosol stonechip is shite, the reason being it has to be so watery to be able to be sprayed out of an aerosol can that it is not thick enough to get decent build on a panel. You need a proper underseal/Shutz gun and compressor to do it right.
1st May, 2012 at 05:05:18pm
I've got this stuff:
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
1st May, 2012 at 05:09:32pm
i used the stone chip out of an aerosol on a couple of sill repairs on my old astra and the stuff just peeled off after a couple of months. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
1st May, 2012 at 06:16:08pm
Stonechip's too heavy. :)
Andy, if you need to borrow a gun you can, i was thinking you might be better with a 1ltr of etch rather than aerosols ???
319 Posts Member #: 1742 Senior Member essex |
1st May, 2012 at 06:19:22pm
yep etch prime then seal all seams allow to dry i have used various materials depends what we have in at work. Wurth sks, upol raptor (hard stuff Edited by jlay on 1st May, 2012. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
1st May, 2012 at 08:07:53pm
On 1st May, 2012 cossierick said:
Andy, if you need to borrow a gun you can, i was thinking you might be better with a 1ltr of etch rather than aerosols ??? Mayo, 2k unerneath would be fine on its own so long as its got a good ground (etch ) coat first. Presuming thats the look your after Cheers Rick. I've got the etch and thinners already. A reasonable gun is waiting for me at the post office. The stone chip goes on with a gun, got that too I'll be stealing Mike race's compressor at the weekend. May even give it back at some point
1st May, 2012 at 08:37:41pm
Use a waterbased stonechip rather than a solvent as solvent base stays soft and the colour coat cracks I seriously doubt it! |
1st May, 2012 at 08:46:13pm
The wurth sks i use is water based and the upol raptor is a 2 pack product i think it is designed for truck beds or something but i like the texture and toughness. My small bore turbo project http://www.turbominis.co.uk/forums/index.php?p=vt&tid=473901 |
288 Posts Member #: 6267 Senior Member Bristol |
1st May, 2012 at 09:12:58pm
I've just stonechipped the inside of a wing using the type that you spray from a gun and I was impressed with the results, it gave a nice even finish and looks like it should be very resilient. I had no problems painting over it, but I was using cellulose.
) etc. Then i paint in 2k body paint sometimes with a rubberiser addative. I do prefer body colour underside looks tidy and i find easier to clean
