| Home > Help Needed / General Tech Chat > dash pot | |||||||
621 Posts Member #: 393 Post Whore Oulton Park |
13th May, 2005 at 12:15:32pm
what is the best oil to put in your dash pot on the carb |
13th May, 2005 at 01:41:53pm
Everybody seems to have different opinions on this. You can get proper SU oil. I have used 3 in 1 in the past but am currently using 20/50.
568 Posts Member #: 102 Post Whore Pennsylvania USA |
13th May, 2005 at 04:11:33pm
I use 20/50 also |
13th May, 2005 at 04:28:23pm
20/50 here too. -MINI CLUBMAN 1380 TURBO- |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
13th May, 2005 at 09:13:45pm
i used fully synthetic in my old na 1380,
13th May, 2005 at 10:42:23pm
stp oil treatment its supurb and only need topping up ocasionaly always looking for them bigger bunches of bannanas |
14th May, 2005 at 02:24:11am
i did use 3in1 and have just put 20/50 in, now i have a popping on overrun, why's this? |
14th May, 2005 at 09:02:09am
I use 20/50 or gearbox oil in the turbo. But a much thinner oil works better in an NA motor. Well that's my experiance.
14th May, 2005 at 12:25:04pm
On 14/05/2005 02:24:11 greypride said:
i did use 3in1 and have just put 20/50 in, now i have a popping on overrun, why's this? Because the thicker 20/50 means the dashpot piston falls more slowly when you shut the throttle, meaning the mixture stays rich, hence your popping noise as the fuel burns.
14th May, 2005 at 01:57:28pm
ah goood, just as long as it isnt running lean!! |
15th May, 2005 at 10:19:03pm
i've put motorbike fork oil in mine put the plunger isn't that free! |
