Home > General Chat > actuator/boost pressure test with actuator/turbo insitu
welshdan
Member #: 1111
s wales
i have booked my car in for a rolling road setup at the start of next week.
is there any way that i can test the boost pressure with the car stationary in the garage?
its a cossie actuator, set at a slightly reduced preload. i was hoping for a baseline of around 6psi but would like to test the baseline boost pressure if possible before getting to the rolling road? is there any way that i can do this with an air line and boost pressure gauge?
otherwise i will take the cossie one off and fit a standard metro one for now, and bleed up to the required boost. am i right in thinking that half a hole preload on a standard actuator would give around 4psi as a baseline?
any help or suggestions apreciated, cheers, dan
pump up the actuatot with a foot pump.
Kean
Member #: 341
aka T2clubby
South Staffs
As Andy says, I used to "T" in a pressure gauge and foot pump to see the operating pressure.
welshdan
Member #: 1111
s wales
Thanks for the advice chaps. Im not sure that i have a foot pump. Is there any reason why this couldnt be done with an airline with a gauge inline? Cheers, dan
Your plan will work.
yep i used my welder reg and co2 cylinder, because its the mots accurate gauge i had
welshdan
Member #: 1111
s wales
cheers chaps. im going to get the compressor fired up with an airline on it, 'T' in a spare boost gauge that i have and give it a go when i get home tomorrow. need to find a suitable t piece in the garage. thanks for the input, dan
welshdan
Member #: 1111
s wales
Also what am i looking for? Is it when the arm starts to move or when it has moved full travel? I presume its when it starts to move? Cheers, dan
welshdan
Member #: 1111
s wales
i have tested this this afternoon. the wastgate starts to open at 6psi aprox. does this mean that the baseline boost on the car will be 6pi? it has a stiffer spring than the standard metro item, the wastgate fully opens at aprox 15psi. my thought is that when the wastegate starts to open then that will be it? can anyone please clarify this for me? i have the rolling road setup very soon and the operator wants the base actuator psi set to 6 as a safe bet for my engine. cheers, dan
