| Home > General Chat > Force Racing New Euro M 10" Wheel - cooling ? | |||||||
8 Posts Member #: 9714 Junior Member |
19th May, 2012 at 08:28:17pm
Hi Carl,
1226 Posts Member #: 9271 Post Whore Stoke on Trent |
19th May, 2012 at 08:40:34pm
Not a lot different than a car with full width wheel trims fitted on steel wheels, Edited by wez on 19th May, 2012. one day boost will be mine!
On 10th Mar, 2012 Joe C said:
TBH peple stick it everywhere... and theres merits to each... |
1391 Posts Member #: 1686 Post Whore Oxford |
19th May, 2012 at 09:33:35pm
Depends on how the brakes are cooled in the first place. Id argue the point that there is not a great pressure differential between the two sides of the wheel due to the dish on one side and the shrouding on the other. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
19th May, 2012 at 10:21:50pm
They will be fine :) my mate has moon disc on his beetle they never over heat |
19th May, 2012 at 10:26:34pm
Theres not a problem with cooling as There is more! than enough airflow around the discs
869 Posts Member #: 2443 Post Whore Cheshire |
20th May, 2012 at 08:45:06pm
My guess would be that the big hole on the other side should eliminate any heat build up, unless it was being raced very very hard! |
20th May, 2012 at 08:55:01pm
These are based on the old McNally wheel, Vizard used to race his car very hard on those with no problems - there will be no problems with these either I seriously doubt it! |
20th May, 2012 at 09:13:16pm
On 20th May, 2012 paul wiginton said:
These are based on the old McNally wheel, Vizard used to race his car very hard on those with no problems - there will be no problems with these either Hillclimbing
20th May, 2012 at 09:17:51pm
Yep
20th May, 2012 at 09:21:27pm
Mcnallys were fantastic looking wheels, got to be one of the all time bests |
20th May, 2012 at 09:21:55pm
I see no problem with overheating brakes on the Euro M, the disk backplate would cause more problems if fitted,
21st May, 2012 at 06:16:49pm
ok thank you for the replies !
Edited by Driezzie on 21st May, 2012. |
