Home > Beginners Tech > fuel?
shaggy591a
Member #: 9624
Seattle, WA USA
My mini is set up with the metro turbo. However I am not running a turbo at the moment. I have dropped in my other 1275cc motor from my other mini. Can I use the upgraded fuel pump and metro turbo fuel regulator on my NA motor. Or should I use the mechanical pump that is on my 1275?
1991 mini cooper
1971 mini clubman
It will be fine to use the turbo setup. Obviously you won't connect the boost pipe to the regulator.
