Home > Help Needed / General Tech Chat > what psi can i run on a 1340 supercharged
page90jack
Member #: 9951
BRIGHTON
hi i just seeing how much psi i can run my 1340 supercharged 8:1 ratio ?
What supercharger do you have? presuming it's an M45, 10 psi is a useable max on suckthrough. Blow through maybe a bit more, but you're on the limit of the useable efficiency much above 10psi.
page90jack
Member #: 9951
BRIGHTON
yeah its a m45 some one said i can run 15psi but thats to much?
You could run 15psi, but you'll probably not see much, if any gain over 10psi like Wil said.
There is a good thread on here where it was shown that there was a gain of 5bhp between 9psi and 15psi. If you have an IC on a blowthrough you can get the charge a bit cooler, so you may get away with more than 10.
page90jack
Member #: 9951
BRIGHTON
ok thanks how can i get it to 10psi i got a 110mm crank pulley and a standard supercharged pulley?
jameswildcooper
Member #: 1355
Leicester
if its blow through you should be good for around 14psi which is what im running. im hoping for around 150-170bhp
i have it in my mind, but it may be drivel borne of over exposure to tinned peaches , that the bini s runs 12 psi stock ,and pulley kits put it up to 15 psi ,for around 220 bhp .(with cam and head work etc )
Edited by robert on 30th May, 2012.
jameswildcooper
Member #: 1355
Leicester
no they run 8Psi standard....
Chalkie
Member #: 9764
Northamptonshire.
I thought they ran 10 Psi standard
we're doing a Intercooler and Remap change on the Bini should be good for 230 bhp :)
see ,too much peaches ,..
http://youtu.be/oqN0JgUt8No
10 psi it is ...you get the next can ,ridinglow!:)
and for blower whine addicts ...17psi...
http://youtu.be/iR56A8JBCkQ
Edited by robert on 31st May, 2012.
Chalkie
Member #: 9764
Northamptonshire.
Ahh thank you :)
and the whine noise is loverly!!! why I want a super charger :)
If its just the noise you want, why not go turbo and use the supercharger for windscreen demisting?
