Home > Beginners Tech > Downpipe Clamp
mossy2a
Member #: 9751
Derbyshire
HI,
i know pwople modify the standard clamp etc and i hear they are not the best for sealing etc, in my work i occasionally use the heavy duty clamp in the picture below.
http://image.made-in-china.com/2f0j00deNtR...-Tri-Clover.jpg
Has anyone ever used this or similar. It is basically a v clamp with a hinge on one side and an m8 nut on the other. i have trial installed in on my elbow and downpipe and it gives good even clamping.
They are desiged for 2" od pipework so have enough clearance. the only thing i can think is the wing nut does stick out a fair bit but nothig a grinder or replacing with a normal nut won't solve. they are stainless and cheap also.
i will take a photo of my downpipe and post when i can.
any thoughts from you knowledgable chaps, do you think it will do the job or am i being a tight git and should just buy the noraml one.
David
David your been a tight ...lol
I have modded one new in the pic the so called hi pressure one... pm me if you want on
Users viewing this thread: none. (+ 2 Guests)
