Home > Help Needed / General Tech Chat > Swapping Cylinder heads?
shaggy591a
Member #: 9624
Seattle, WA USA
I am swapping cylinder heads on my mini with a donor motor I have. Mine is cracked. I have never done this before and am following the haynes manual. Is there anything I should do before I start fitting it on? Is there also something I should do that is not in the manual that should be done too?
1991 mini cooper
1971 mini clubman
wng691s clubby
Member #: 9252
Cleethorpes
just make sure you torque it up correctly and in stages
Done now needs redoing lol
Haynes has this one well covered. A few people have added their own little tweaks (like torquing up after a heat cycle), but they really aren't needed.
Chalkie
Member #: 9764
Northamptonshire.
I do this on some cars Eg Rover v8's mainly alloy head and block motors just to be sure
Mini ill run it round from front middle out in a spirl then back around just to be sure
bennyy
Member #: 9037
Doncaster, yorkshire
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Looking at the photos of the damaged head, I'd say you were unlucky last time;
Do you have one of the ultimate engine steadies? I'm just wondering if the action of this on the thermostat housing studs was the cause of a weakness? alternatvily hydraulic action of any fluid in the head when the bolts were tightened?
in short, it would look like the issue revolved around the thermostat housing and nothing to do with the actual fitting of the head itself
Torquing the head nuts down, start at the centre stud and work your way out in a spiral
bennyy
Member #: 9037
For some reason I thought he meant something different lol
Chalkie
Member #: 9764
Northamptonshire.
Sorry! my spelling is a bit iffy on some words :( but yeah Apbellamy hit the nail on the head
bennyy
Member #: 9037
mattsmadmini
Member #: 9965
Sydney, Australia!
agreed.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
i re check the torque after a good few miles, and i read it different too benny i though he meant start in the middle and work round the head
shaggy591a
Member #: 9624
Seattle, WA USA
I didn't have one of those steadies. I did have to replace that side engine mount when I dropped that motor in the clubby. I pulled the head off the donor motor and took a few stuff my motor to get ready for the swap. Will pull my head off tomorrow and clean up and install the donor head on.
1991 mini cooper
1971 mini clubman
Torque. It to 50ft pound if its not a Turbo engine, if it is 55ft pounds
bennyy
Member #: 9037
That's what I thought lol
