| Home > Help Needed / General Tech Chat > Fitments sizes and turbo cooling oil feed | |||||||
![]() 163 Posts Member #: 9865 Advanced Member |
5th Jun, 2012 at 07:16:27pm
Hi Guys,
5th Jun, 2012 at 07:23:16pm
Go to your local hydraulics place. If it's a T3 then you want a 3/8unf banjo bolt on the turbo end and a 1/8 NPT straight fitting on the other end. They usually cost me about £15. On 11th Feb, 2015 robert said:
5th Jun, 2012 at 07:43:41pm
excellent cheers, just had an idea iv found various tpieces and fitments all 1/8 bspt or NPT i believe because they screw into the block. so ill take your advice and ring around tomorrow.
5th Jun, 2012 at 07:51:30pm
Just wanted to double check that these are t3s?
6th Jun, 2012 at 07:07:09am
they look like T3s from the pics. a shot from above would confirm it On 11th Feb, 2015 robert said:
6th Jun, 2012 at 07:11:18am
Yeah they are t3's. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
6th Jun, 2012 at 11:54:19am
think auto are your friend. give them a call with what you want and they'll sort you out :) |
6th Jun, 2012 at 10:18:56pm
Sweet thanks for the help guys. |
7th Jun, 2012 at 06:31:21pm
Just to add on I Got a quote from Carlton hydraulics in Rotherham.
7th Jun, 2012 at 07:07:16pm
That's who I use as they are local, not sure on the length. On 11th Feb, 2015 robert said:
7th Jun, 2012 at 07:22:14pm
What you can do is get them to only swage one end. Then you can offer the hose up to your engine and decide the exact length you need. Take the hose back and they will swage the other end.
7th Jun, 2012 at 08:47:09pm
Yeah I'll do a bit of name dropping, I don't think I'll be able to pop back as I'm in Hull but going to tie it in with going to p&l minis.
7th Jun, 2012 at 08:50:34pm
There around 600mm-700mm on my gt20 depending on how you route it. Audi s4 b5 - 470bhp & 486ft lbs
7th Jun, 2012 at 09:00:49pm
Spot on 700mm it will be.
