Home > Wanted > oil pump adaptor - spider drive to slot drive
mossy2a
Member #: 9751
Derbyshire
does anyone have one for sale, or have i got to get the machine shop to make me one?
http://www.minimaniauk.co.uk/images/12g729mm.jpg
David
David, just buy a spider drive pump for 14 sheckels, job done from minispares
it will save you a lot of knob ache!
there are 4 bolt hole patterns on the block .....iam sure they are interchangable
mattsmadmini
Member #: 9965
Sydney, Australia!
If need be i can get a chap here in australia to whip one up for you. Let me know.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” - Jeremy Clarkson
mossy2a
Member #: 9751
Derbyshire
Cheers chaps for the replies, could not get a spider pump from minispares so am getting my machine shop to make me a shiney stainless steel one.
cheers
david
Rab-butler
Member #: 10543
Hi there mattsmadminis i have the same issue, what would be the cost of getting the slot drive adaptor sent to the UK?
Rich
mossy2a
Member #: 9751
Derbyshire
as its a while ago, you may be wiser sending him a private message.
just fit the appropriate pump
mossy2a
Member #: 9751
Derbyshire
i thought you could only get the turbo pump in slot drive??
turbo pump not needed ...............only IMO with BILLET oil fed X drilled camshaft
Cables69
Member #: 10196
I was just thinking that, shop around i'm not impressed with minispares/minisport's stock they never seem to have anything in i want, so i end up going down the road anyway to the local guys and they have several
Rab-butler
Member #: 10543
Thing is, i would buy the spider drive oil pump but my camshaft has not got the teeth inset for the spider drive, its as if its missing something, was off ebay mind, so trying to get hold of the adaptor piece is really the way ahead, either threw matey or see if i can get one manufactured :s
