Home > Wanted > Wanted Stupid Little Engine Bits....
I stripped my engine down so long ago I have managed to lose a few small but important engine bits.........
I am loathe to pay Minispares/sport ?8 for the priviledge of them posting me said parts as well, a pair of idler gear thrust washers dented my wallet enough this month anyhow....
So I need if anyone has them-
1) The oil thrower plate that sits on the end of the crank, inside the timing cover
2) The dowels that locate the engine to the gearbox
3) The short studs (I think 2 or 3 off?) that go between the engine and gearbox
Anyone able to help will be rewarded handsomely!!!!!!!
Tom
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
catch me on msn TOm and I'll post them to you!
Alex
AlexF
Splendid, cheers.
Tom - the studs are a reallllllllllllllllly soft steel. I use cut-down cap head bolts instead, with the gearbox casting ever so slightly relieved so you can physically fit them (and a cut-down allen key). Just a thought if you're planning on many bananas!
D
Hmm useful info cheers Dave.
What I might do instead is get some 1/4" set screws of a decent grade and then make my own studs by cutting the heads off, thus giving the best of both worlds (easy to fit but good and strong)
Bananas Bananas Bananas we all love bananas.....
I've used 5/16" UNF bolts for some time... Works fine....
The problem with Allen bolts, is that there's NO room to tighten them back there..
??? There is tons of room...
Dangerous
Member #: 417
should that be unc ? I was going to use M8,just bought a piller drill to do this and 11 stud the block,maybe jets too as local engineering place wanted loads ££
