Home > Help Needed / General Tech Chat > Has anyone installed a paddle clutch?
darkviper222
Member #: 9904
Hi all,
I am looking at fitting a paddle clutch to my weekend turbo track mini and was wondering if anyone has any experience with using this type of clutch ie: is it as indestructible as its claimed? and is it worth changing from a race type clutch kit you can get from any good performance mini parts supplier?
I am aware or this rts idea but still do not completely understand it.
Any help would be great!!
thanks*happy*
I had a paddle plate in my last build with a single grey, no real problems with it, it slipped less than the organic "race/rally" plate but when it did slip it generated much more heat, depending on the weight of your car i would say its not necessary under 160 brake
Edited by wolfie on 11th Jun, 2012.
Johnny
Member #: 6926
Accrington
i had a grey plate and 6 paddle friction plate. i was running approx 180bhp and somewhere around 160 torques :)
No slippage
I run a paddle plate in a standard verto. The organic plate slipped, and the paddle doesn't.
Edited by wil_h on 11th Jun, 2012.
eden7842
Member #: 8852
leicestershire
Who dosent run 1
I would opt for the 5 finger paddle friction plate, this on is forgiving its not like a switch on an off feels more like a normal clutch and holds torque.
Available from minspares
darkviper222
Member #: 9904
Thanks to everyone for your replies. It is very helpful and should make my desision on what clutch plate I should use a lot easier ! Thanks again
