Home > Beginners Tech > what size
wng691s clubby
Member #: 9252
Cleethorpes
what size wire sould be used for loom wiring, wanting to wire up megajolt
Done now needs redoing lol
I used 1mm thin wall for the majority of my loom.
Same as above ^^^ 1mm for most of it.
wng691s clubby
Member #: 9252
Cleethorpes
cheers guys
Craigie-B
Member #: 9468
Wootton Bassett
what didnt you use 1mm for? shielded cable? Anythign else?
Cheers :)
I used 3mm thinwall for the supply from the battery to the distribution fuse box, from there to the main relays and from there to the fuses.
