Home > General Chat > K1200 and K100 Exhaust Ports
Chaps, does the K1200 and K100 share the same size exhaust ports and stud distances?
IE could i chop up a K1200 manifold to make a k100 manifold?
Mike
Advantage
Member #: 1450
Near Paris - France
K1200 as in 16V ?
And K100 as in 8V ?
That would be strange if those would share the same exhaust port size, given the capacity increase and all ...
Rusty by nature
Flo
Member #: 6322
Bawdeswell, Norfolk
I have the 8v in my Marcos. I use the same standard down pipe that SC make... so I'd assume they are the same!
Thanks guys, Ive ordered a k1200 set of headers now, but only paid 35.00 delivered for them so Ill let you know if they fit.
CHeers
Mike
Headers for the K1200 'flat four' or 'across the frame'
The two are very different
The manifold i have bought look very similair in design to the sc one except the bottom of course
Hither
Bargin
That should do the job nicely with a bit of surgery.
not wanting to be the bearer of bad news, but that looks to me to be for the 'across the frame' k1200's' and not the 'flat four' k1200'rs'
*frown*
you might be able to use it of sorts but will need a fair bit of adaption.
Oh Colin you and your negative ways a quick trip to planet Austin and were good to go lol
Chaps just an update on this,
The Ports are indeed larger on the k1200 which colin states. However the port spacing and stud patterns will work fine. So its not been a waste of money and time as the manifold will do nicely as a starting point.
Mike
