Home > Help Needed / General Tech Chat > Headgasket failure analysis N/A 1380
I was driving along yesterday steadily through the village and noticed the car running rough, sounded like an exhaust blow, I then realized it wasn't so parked up and got towed all of 1.5miles home (Glad I didn't try to make it home now.)
Thinking it sounded like a carb issue I inspected that but it seemed fine, so whipped out the compression tester and sure enough cylinders 2 and 3 were dead.
The first thing that struck me was the light colour of the spark plugs, as illustrated by the combustion chamber colors.
I'm wondering whether it has gone lean and lightly toasted it as I heard the fuel pump sucking fuel about 12 miles before the actual faliure, upon some hard cornering, so took it easy to allow the fuel to flow through again, even so the engine did not miss or cough. It had had a kicking about 5 miles before it failed after filling up with fuel. (Tesco 99 octane) When it failed I had been taking it easy for a good 3 miles.
What are peoples verdict on these photos. The middle two piston crowns have some hard carbon deposits almost like welding splatter. If that is of any use for identifying the failure who knows.
I have shown photos of cylinder 1 and 2 to show the difference in colour. Usually they are not so abruptly different.
On the plus side I have had the opportunity to decide where to slot a gt17 down the back with the 16v head should I so decide to go down that route, and replace my crappy old manifold with a new one.
Cylinder number 1
Cylinder number 2
Edited by minimole23 on 25th Jun, 2012.
Ill put money on the Tesco fuel being the culprit
jamie@thefatgarage
Member #: 9345
Sheffield
I doubt its the petrol. The octane rating is pretty strictly controlled and I don't think the lack of additives others may use in premium fuels would make enough difference to kill the gasket. Certainly not if 97 octane is ok normally. I think the clue is in hearing the fuel pump sucking is a good pointer, it's been starved and gone lean enough to cause a problem.
I will be fitting my fuel swirl pot as soon as I get it cut down, and re-welded.
Here are the spark plugs.
i am far from an expert but the plugs look like the engine has been running leaner than i would run personaly
I agree, brown for cruise, black for power.
Unless those plugs were removed after shutting the engine down immediately after the blow, they bare no relevance whatsoever to how it was running at the time.
From the head it looks like it has been running generally lean. The damage to the gasket is definately pinking/det damage.
A bit richer or a degree less advance may help.
If you have a carb, then don't waste your money on a swirl pot, the carb already has a resevoir (float bowl) for just this purpose.
Ultimately, how long has the gasket been on? they don't always last forever.
Tesco 99 is nowhere near 99 I have been reliably informed. It does look like its been running lean but I still think its the Tesco fuel - especially since Tesco do not allow their own fuel to be put in their own vehicles
The gasket has covered about 1000 miles
100 miles flat out at castle combe, and the rest has been road use and drag racing.
I would say I have this sussed now, the more I think about it.
There is too much ignition advance or not enough fuel going through at about 3k rpm, when hardly touching the throttle. what to me seemed like a miss/camminess/general hot cammed 1380 ness actually was a bit of det, and that has toasted the gasket. hence it failing when taking it easy down hill into the village, not when spanking it up zig zag hill.
I'll get it running, check the advance and get it too a rolling road I think to double check it.
Edited by minimole23 on 26th Jun, 2012.
Well we now have 30 quids worth of fuel for the lawnmowers, I'll get it drained out.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I have heard that the MON is low for the Tesco99 stuff.
On 7th Nov, 2008 Nic said:
naeJ
m
Chalkie
Member #: 9764
Northamptonshire.
The Tesco's near me Is ESSO garage :) there fuels fine. but big tesco's just says tesco so no idea's who's fuel that is
eden7842
Member #: 8852
leicestershire
Bk450 head gasket and shell fuel and ul be away again
AF460 for me!
What is annoying is that the brake backplate had come loose, so had to tighten that up before going for a drive, as a result went to tesco fearing the shell garage would be closed. Nearest petrol station is 12 miles away!
Still, this failure was inevitable if the set up was poor.
Det did cross my mind when I heard the noise, but discounted it for the reasons listed in the other post.
At least I know what it sounds like, for future tuning purposes.
eden7842
Member #: 8852
leicestershire
we all learn from mistakes
Well new gasket on, faces cleaned, all torqued down properly, tdc double checked to make sure the ignition is set properly.
Just need a trip to maniflow to get new centre section for my exhaust as I reckon thats costing me a couple of horse power at the top end.
We shall be back faster and hopefully more reliable!
jonny f
Member #: 9894
Dorking
Did you re-torque it after a few hundred miles last time?
Great! Analysis CORRECT! Although Paul does have a great point about the tesco fuel, this would have helped bubble it over the top especially if its near the threashold on detonation, sadley, the first thing to go is the gasket between 2&3 you were lucky!
Edited by BENROSS on 27th Jun, 2012.
