Home > Help Needed / General Tech Chat > Indicators Stay On
Chaps, im just about finishing up the wiring on the blue mini and im having some difficulties with my indicators, the hazards flash no problem, however the indicators just stay solid? IE they dont flash.
I know one of the relays is buggered but ive swapped them over and they stay the same? Or do Both Relays need to be working?
CHeers
Mike
wng691s clubby
Member #: 9252
Cleethorpes
i dont have relays but i know when mine did this it was the flasher unit behind the speedo housing, sorry if the info's no good
Done now needs redoing lol
change the hazard switch if you have swapped the relays as both circuits got though the switch
there will be two flasher units. one for hazards and one for indicators. sounds like your indicator one is shot or not earthed properly. indicators behind clocks, hazards on the engine bay bulkhead
Ill try the relay first, then ill try a new switch.
Cheers lads
Chuck the crap bi-sexual flasher unit in the bin. then buy a modern flasher unit. To connect it up is easy, you just need to run an additional earth wire.
Then you'll have reliable consitant-rate indicators. Rather than random flashing dependant on the weather.
So im after a 3 prong flasher then wil?
Yes mike i recomend 100%
Are you using the standard switch?
If not you'll need some extra gubbins.
Yes 3 prong (usually 4x21W iirc).
1) One prong 12V
2) One prong to stalk
3) One to earth
1 and 2 above are what is already wired to the existing shitty bi-sexual flasher
What about hazards?
I just use the standard one it's more consistant in operation than the directional one.
It's not like you ues hazards much anyway.
Err have you seen my car?
Yep all standard stuff going on this, barring whats under the bonnet
If theyre on and not flashing it'll be a flasher unit problem. To be honest I've never had a problem with them not working properly, I've only ever had them not working at all the once when the flasher died. So i keep a spare in the car, they don't weigh anything to carry about if it's a daily motor.
This did turn out to be the relay, cheers chaps
When you say relay, you mean flasher unit, right?
Sorry yes I mean flasher unit.
