Home > Help Needed / General Tech Chat > Turbo Intake hose/filter
big_blue_bug
Member #: 9966
Norwich, Norfolk
Hi guys,
First of many questions to come, I recently picked up my first Turbo Mini - Aaron/Rubicon's old car. There will be a build thread shortly, but just a quick question.
Currently there is no air filter or intake hose on the turbo - whats best to use for this? is standard silicone hose ok, or something more substantial?
Also any reccomendations on filters?
thanks for your help
Ben
t@z
Member #: 452
Chester, UK
hi & welcome :)
http://www.apmotorstore.co.uk/air-ductings...ne-ducting.html
www.twitter.com/lilpinkiy
t3gav
Member #: 229
Gavin@minispares.com
kent
You need the 60mm one btw :)
bennyy
Member #: 9037
Doncaster, yorkshire
Depends which turbo he has
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
big_blue_bug
Member #: 9966
Norwich, Norfolk
I believe its a GT15 if that helps....
big_blue_bug
Member #: 9966
Norwich, Norfolk
Can i clamp this down on the turbo or is it just for ducting?
bennyy
Member #: 9037
Yeah you can use that straight from the turbo. I'm not sure on the size, but I think the gt17 are 51mm, my gt20 is anyway.
big_blue_bug
Member #: 9966
Norwich, Norfolk
thanks guys, will measure up tonight to get the right size.
any opinion on filters?
t3gav
Member #: 229
kent
Oops I assumed it was a standard setup.
bennyy
Member #: 9037
I use a green cotton, they were available from avonbar before they closed, minispares do a k&n one but you may need a stainless hose reducer thing
welshdan
Member #: 1111
s wales
I also use a green one, may be available from ian at avr. Cheers,dan
t@z
Member #: 452
Chester, UK
i use minispares turbo k&n with just a bigger bit of silicone hose squished between the 2 as i had it spare.
Mike-998
Member #: 9774
Buckinghamshire
Air filter wise, If you're patient you can find some good deals on ebay.
I got a green cotton filter for a 206 for £20.
