Home > Technical Chat > GT1548 v R5 T2
alaskanow0
Member #: 8466
Mansfield
Can anybody tell me the benefits of the GT1548 over the Renault 5 Turbo. I know they are share the same flanges and both fit the mirage manifold. Just interested in efficiency, spool time, max boost / power. Looking to run 10psi max @ 9.75CR on 7 port.
The compressor maps are almost identical. That's as much as I know. There is probably no real advantage, but the GT15 may have a more efficient turbine, but this is pure speculation on my part.
What 7 port Matt? The webcon one?
Its a Pedigree Chum one isnt it? *hehe!*
Craigie-B
Member #: 9468
Wootton Bassett
I just presumed they made the gt1548 to replace the t2 as a more modern version?
Is the size of it and different?
alaskanow0
Member #: 8466
Mansfield
I'm not sure at this stage. I keep thinking about converting the red mini back to n/a with the webcon head and more weight reduction for Class B. Then maybe the SC 7 port head, itbs & and there new plenum for the clubman with low boost, mild cam, T2 etc.
You need to make your mind up laddy!!!
You've got an engine addiction problem! *smiley*
How many engines have your mini's had in them over last 3 years? lol
Super Charged
Miglia
Nearly 7 Port
Turbo
Super Charged
Miglia
Nearly 7 Port
Turbo
and your on with an 8v twwin cam somewhere
