Home > Help Needed / General Tech Chat > What the fook is wrong with my fan?
Craigie-B
Member #: 9468
Wootton Bassett
Hello boys and girls *happy*
I bring more questions about my silly engine build.
iBought one of these fans:
Lovley.
Went to fit it and this is the case:
So put some longer bolts and 2 washers on each and its like this:
What am I doing wrong? My housemates got the same fan and it fit with just using the spacer?
Is it okay to put a third washer in? Seems a bit silly to me :/
Craig
Edited by Craigie-B on 3rd Jul, 2012.
Craigie-B
Member #: 9468
Wootton Bassett
just to add to this some of the blades touch the breather and some clear it? How wierd?
oli79
Member #: 8480
Looking at it, you would be better off with a flattened breather
On 5th Oct, 2014 Shauna said:
The Morris Ital assassin!
Craigie-B
Member #: 9468
Wootton Bassett
I havent got any more timing case gaskets :/ I waas hoping to get engine in car tomorrow
Old trick is smash the breather on the timing cover flat.
Take the fan off, and take the hammer to the breather. Simple!
Craigie-B
Member #: 9468
Wootton Bassett
ok, fans already off lets bust out the hammer :)
is it fragile or should i give it some proper wrath
Hit it as hard as is necessary to clear the fan, don't go paling the crap out of it straight away lol.
Put something behind it if you can for a bit of support.
Edited by Carlzilla on 3rd Jul, 2012.
Craigie-B
Member #: 9468
Wootton Bassett
ok thanks buddy :)
Bin the shit heavy metal fan and put a plastic one one.
The metal blades have no shape to them, and don't move anywhere near as much air as the plastic ones with a proper blade design.
just make sure you don't damage the case or crack where the brether connects in;
wng691s clubby
Member #: 9252
Cleethorpes
could use a different sized spacer
Done now needs redoing lol
I agree with Wil, ditch the hideous fan.
Craigie-B
Member #: 9468
Wootton Bassett
Ahh man :( I just bought it because it said it was good for fast road engines!? and hotter climates!?!?!?!?!
hotter climate? Have you not seen the weather lately?
mercenary62
Member #: 9937
yeh get rid of that heavy old outa date metal fan ,and get a plastic one with a spacer
give em hell
eden7842
Member #: 8852
leicestershire
I love my 6 blade fan
adrian
Member #: 2726
wakefield
Paint it red, bang it on ebay saying it will give an extra 5 BHP, should sell in no time *wink*
mercenary62
Member #: 9937
lol nice one adrian
give em hell
wng691s clubby
Member #: 9252
Cleethorpes
only 5bhp
sim_ou_nao
Member #: 114
Porto/Portugal
I have the same issue Craigie, if you put a spacer you need to modify your top radiator bracket, and is a pain in the ass to fit the radiator with the spaver in the fan!!!
I modify my timing cover, but for that you need a new gasket...
Edited by sim_ou_nao on 3rd Jul, 2012.
Pedro Silva
Chalkie
Member #: 9764
Northamptonshire.
Don't you mean zapps an extra 5 BHP away from the engine.
I always got told get rid of the metal fan and you gained BHP
(I have a 4 blade metal one again ;])
Chalkie
Member #: 9764
Northamptonshire.
P.s when I brought my mini My spacer was between the waterpump and the water pump pully so it cleared it that little bit more not sure if this was wrong.
Craigie-B
Member #: 9468
Wootton Bassett
ahh okay, well it fits teh engine so far I will try hold the rad against it tomorrow and see how it is, if it catches then I may have to chop the breather. The top bracket I was using is from a 998 so will need modifying anyway :)
ntm1275
Member #: 9395
I've never had fan clearance problems as I use the larger spacer in the link below
