| Home > General Chat > 1380 block build advise | |||||||
![]() 641 Posts Member #: 9937 Post Whore somewhereintheuniverse near selkirk scotland |
5th Jul, 2012 at 07:50:13pm
just bought an offset bored 1380 block off a mate bores are 73.5 i take it i can use the metro turbo rods i have and use powermax pistons ,il also be using a wedged and balanced and tufrided crank ,and a slark stage 4 head i have lying around ,any advise on building this up would be good its going to be run on a weber 45,also has anyone fitted a 11 stud head onto a 9 stud block ,boring and taping the block themselves give em hell |
5th Jul, 2012 at 07:59:08pm
Thatel all be fine 13.95 1/4 mile on a 2.95 fd. Carnt be that hard to beat! |
5th Jul, 2012 at 08:43:50pm
What cam are you considering? what will you be using it for? On 7th Oct, 2010 5haneJ said:
5th Jul, 2012 at 09:38:05pm
fast road was thinking sw5 give em hell |
5th Jul, 2012 at 09:38:46pm
If the blocks already bored, but your getting some pistons then the chances are it wont be bored to give the correct clearance for the pistons you have, unless you're very lucky. |
5th Jul, 2012 at 09:42:43pm
On 5th Jul, 2012 mercenary62 said:
fast road was thinking sw5 ! I suppose that would work well, but I would be tempted by something wilder! On 7th Oct, 2010 5haneJ said:
1391 Posts Member #: 1686 Post Whore Oxford |
5th Jul, 2012 at 10:16:00pm
I dont understand why youre putting a weber on it only to put an awful camshaft in it.
Edited by Sam on 5th Jul, 2012. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
5th Jul, 2012 at 10:28:14pm
ok its up for debate , which cam is best for this build bearing in mind its for fast road give em hell |
5th Jul, 2012 at 10:35:53pm
895 in mine is a pussycat with basically the same spec as yours. Easy to pull away and takes off at 3k.
6th Jul, 2012 at 11:02:22am
286, beautiful road cam in a 1380 withe a good head. 296 is not a rad cam. On 13th Jul, 2012 Ben H said:
250 Posts Member #: 1615 Senior Member Ferndown, Dorset |
6th Jul, 2012 at 03:19:03pm
On 6th Jul, 2012 Vegard said:
286, beautiful road cam in a 1380 withe a good head. no issues with this set up in my car On 1st Mar, 2009 MikeRace said:
Hmmm weberyyy On 21st Apr, 2009 madcatminis said:
I hope she's got knickers on or you'll have a funny runny mark on your bonnet. Quite like what a snail leaves behind. |
6th Jul, 2012 at 06:27:55pm
yeh thinking now il use the kent 286 with new followers ,and a swifttune vernier i picked up, by the way any ideas on manifold im thinking of using maniflow coupled to an rc 40 give em hell |
