Home > Technical Chat > Basic components for turbo engine
Ben Smith
Member #: 7517
Hereford
Hi guys,
Just starting new build. Very much track focused with full miglia spec cage etc but will still be road legal.
Have done a bit with A series but not turbos. Now I know people will have preferences but what basic components work together? Turbo, manifold, cam etc? I don't expect everyones top secret engine specs, just need pointing in right direction. Want it to be a 1293.
Many thanks
Ben.
the metro turbo ex manifold only fits with the metro turbo inlet manifold, this is the usual combination, or there is the mirage ex manifold that allows a T2 or similar turbo to be fitted with no bulkhead box, or make your own...
cam wise, somthing mild, like a 266, for a stormer go for the AVR/Avonbar phase 2 cam, pistons, use metro turo ones or aftermarket, omega ect, rods and crank std will be fine. cr of 8.5-9:1 depending on use, and an intercooler.
