| Home > Help Needed / General Tech Chat > WiLWood brake calipers | |||||||
55 Posts Member #: 9904 Advanced Member |
15th Jul, 2012 at 04:34:38pm
Hi peeps.
15th Jul, 2012 at 04:41:08pm
Taper threads are for low pressure applications only and should never be used on a hydraulic fitting (which is what this is).
15th Jul, 2012 at 04:49:08pm
Thanks Tom. So if I am to use a cooper washer that means that I should be able to screw the end in flush? |
15th Jul, 2012 at 04:55:19pm
Assuming that there isn't a seat in the bottom of the threaded hole in the caliper, yes. You may need to check length to ensure the fitting can compress the copper washer to seal without bottoming out.
15th Jul, 2012 at 05:21:48pm
Actually some, if not most Wilwoods are a tapered thread, (I think the ford M16 replacements are M10) so its likly that it wont screw all the way in.
![]() 536 Posts Member #: 5449 Post Whore Melton Mowbray |
15th Jul, 2012 at 06:06:35pm
Aren't metro 4 pots tapered thread into the caliper as standard, but the mini conversion uses banjo bolts and washers? On 25th Sep, 2009 mini13 said:
cool, i'll pop over with my tool and some lube, lol 1293 88.8hp 82.2ftlb 17.3 1/4 @ 78 mph Naturally Aspirated (for now) |
15th Jul, 2012 at 08:07:02pm
1/8 NPT on every Wilwood I've had my hands on... On 17th Nov, 2014 Tom Fenton said:
15th Jul, 2012 at 08:37:39pm
My Wilwood PS-1's are M10 I seriously doubt it! |
