Home > General Chat > MiniSport Captive Nut Engine mounts - Thread Warning!
Craigie-B
Member #: 9468
Wootton Bassett
Hey guys, I bought theese a while ago and got around to fitting the engine in the subframe, bit of a pain in the arse to get them to fit but we got there with an engien crane, hammer and tyre lever.
http://www.minisport.com/mini-spare-parts/info_SPD0012.html
We found that they had used a metric threaded nut instead of the standard mini UNF size, instead an 8mm Metric bolt had to use.
Just thought I would post this so if anyone else uses these then they know to get some 8mm bolts :)
Cheers!!
Chalkie
Member #: 9764
Northamptonshire.
Yeah dude they are pretty shit for getting in place! I had them ended up using 8.8 Allen key 8mm screws to get them in
Captive nuts on engine mounts are a shit idea. You just end up with wrecked threads. Pop them out and just use with the normal nut and bolt.
bennyy
Member #: 9037
Doncaster, yorkshire
I agree, they sound a good idea but just don't work, but the Normal nut and bolt mounts are much better
Edited by bennyy on 21st Jul, 2012.
On 15th Mar, 2012 wil_h said:
On 30th Apr, 2012 Brett said:
Agreed with Wil. The threads get wrecked trying to line them up the traditional way and you need to get them bang on to get the bolt to take.
Much quicker with the standard ones in my opinion.
Craigie-B
Member #: 9468
Wootton Bassett
well there in now, the only ones that ruined the thread where the ones that we tried putting the standard unf bolts in.
The otehrs were fine but all in all a pain in the arse to fit and you need to get 8mm bolts.
If I change mounts again I wont be using these again :)
I Put these on my Dads S and found them a piece of piss?
My old engine had unf captive nuts. Never had a problem with them. Nut and bolt types take the piss with all sorts of jiggery pokery to get bolted up.
I think the warning should just be about Minisport stuff in general.
I'm sure if you did a search on this forum, you would find opinion is not great *happy*
It all depends on how cheap you are.
Use genuine Rover mounts and the bolts go in without any of that jiggery pokery. The fact that the non genuine mounts are a different thickness profile means you'll be jumping on the rocker cover in an effort to get them to work.
nala56
Member #: 9661
Sheffield South Yorkshire GB.
I find if you don't line them up right weather they are captive or not, you make a mess of the threads, personally I like the captive type, don't like messing with two spanners..
Main Build
Upgrade to Turbo
I've never struggled to get stuff in place, it's just an arse getting to the mount side to get nuts on/bolts in.
Many a time a magnet on a stick is needed unless you have paper thin fingers.
Carl S
Member #: 1761
Stalker
I used captive nut type mounts a couple of years back with no issues what so ever. They fitted like a dream.
