Home > General Chat > what do you think of these rims
norm74
Member #: 2819
south east, Melbourne, Victoria, Australia
Hey guys and girls
I have been given these rims to buy; they are 12”x4” with a plus 42 offset and 100mm PCD.
Can you please help me with what tyre size, clearance problems and if they just look any good on the car.
Thanks heaps
rob
everybody likes free stuff
mini is 4" pcd so they don't fit.
norm74
Member #: 2819
they bolt up so sorry i got the pcd wrong. im not that swithed on with rims.
Pcd is wrong but you might be able to use some specialist washers to make them fit.
Offset is high for a mini by the look of it but could possibly get away with it depending on the application.
Finally, a 4" rim is narrow. Cooper alloys are 4.5"as an example
I do like the look of them though
madonminis
Member #: 9371
East Yorkshire
as rob says, they are very narrow, look ok tho
i think they look crap! i also would not use wobble bolts there a bodge imo
I think they look ok, but too narrow, and you need to check the PCD if you are to use them.
wng691s clubby
Member #: 9252
Cleethorpes
i think they look good but as above maybe a bit narrow
Done now needs redoing lol
You're a brave man jacking your car up there, I hope there's no engine in!
I've seen many a floorpan bent by being jacked up there, it's bad practice. I won't even do it without an engine just to be on the safe side.
They are the wrong PCD to use safely on a Mini, and this can clearly be seen in the picture. Look like a VW wheel to me so 4x100mm NOT 4x4" which is what a Mini uses.
norm74
Member #: 2819
i have found out the pcd on those rims and they are 100mm x 4 pcd and they are designed for a 1980 models subaru sherpa. some little jap city car. i wont be using them.
as for the floor it is already bent up in that area. the owner before me use to jack it up there all the time. alot of mechanics in Aus think its ok to jack up under the floor pan ( because the car doesnt weigh much*oh well*)
i know its wrong and i wont do it again *smiley*
thanks guys for you help.
