| Home > Help Needed / General Tech Chat > Radiator spacing | |||||||
15 Posts Member #: 10046 Member Wolverhampton, West Midlands |
24th Jul, 2012 at 12:53:45pm
So my turbo is getting inn the way of my radiator. It won't fully come over the fan blades so te engine is getting a bit hot. It's an Austin mini 1969. I am planning on installing an electric fan on the wing t help extract some much unwanted heat.
![]() 2057 Posts Member #: 9252 Post Whore Cleethorpes |
24th Jul, 2012 at 06:44:14pm
have you got any pic of your setup? could always use a kenlowe Edited by wng691s clubby on 31st Jul, 2012. Done now needs redoing lol |
25th Jul, 2012 at 12:19:19pm
here are some pics.. .cheers mate,
25th Jul, 2012 at 12:36:06pm
is it the air filter hose thats stopping it? could try a different fan spacer Edited by wng691s clubby on 25th Jul, 2012. Done now needs redoing lol |
25th Jul, 2012 at 12:43:56pm
No amount of spacing or fans will help, a standard radiator is going to struggle to keep a turbo motor cool. Audi s4 b5 - 470bhp & 486ft lbs
On 15th Mar, 2012 wil_h said:
25th Jul, 2012 at 01:09:49pm
I don't understand?
In the 13's at last!.. Just |
25th Jul, 2012 at 01:32:58pm
On 25th Jul, 2012 bennyy said:
No amount of spacing or fans will help, a standard radiator is going to struggle to keep a turbo motor cool. I think people have had success with The Minispares 2-core. Not? On 13th Jul, 2012 Ben H said:
25th Jul, 2012 at 01:51:53pm
i think his problem is fitment aswel as cooling Done now needs redoing lol |
25th Jul, 2012 at 08:40:18pm
that looks to me like the rad is on the std bottom mounting with no top mounting and is pushed away by the massive turbo intake pipe Yes i moved to the darkside |
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
26th Jul, 2012 at 06:52:51pm
How is the top of the rad mounted? The fan looks too far from the rad. |
27th Jul, 2012 at 08:01:06am
it is attached via, a zip tie, and yea i agree with the fitting is an issue as well.. looking to purchase a air pipe to reroute the filter to the front right hand side of the engine with a one-ply silicone Samco Samflex Brake And Air Intake Ducting... just need to get the diameter? is it standard?
31st Jul, 2012 at 05:27:19pm
31st Jul, 2012 at 05:28:57pm
On 25th Jul, 2012 Brett said:
that looks to me like the rad is on the std bottom mounting with no top mounting and is pushed away by the massive turbo intake pipe |
31st Jul, 2012 at 05:30:17pm
On 24th Jul, 2012 wng691s clubby said:
have you got any pic of your setup? could alway i will kenlowe |
![]() 825 Posts Member #: 9661 Post Whore Sheffield South Yorkshire GB. |
31st Jul, 2012 at 05:40:30pm
I think you need the air intake pipe to be the type with the metal coil spring embedded inside the silicon pipe to be able to stand all the knocking around that it gets when you route it between the radiator and bulk head.. Alan. Main Build
31st Jul, 2012 at 05:54:10pm
is that one like this,:
On 31st Jul, 2012 nala56 said:
I think you need the air intake pipe to be the type with the metal coil spring embedded inside the silicon pipe to be able to stand all the knocking around that it gets when you route it between the radiator and bulk head.. Alan. |
31st Jul, 2012 at 10:34:16pm
that looks the stuff just use a hose clip or jubilee
