Home > Help Needed / General Tech Chat > Brake master cylinder
Mini_Andy
Member #: 432
Evening, how do you get the brake master cylinder off, i thought you had to remove the split pins on the pedals but i cant get to them *frown*
or is there a trick to it?
ta
Andy
Depends which type you have. If its the non servo type then yes you need to get to the split pin and clevis on the pedal, and yes they are bloody awkward!!
Nick
Member #: 154
Midlands
super long nose pliers...or hands like a kiddy fiddler is the trick.
i had to get my mate to do mine for me as i've got proper fat hands..lol
Dangerous
Member #: 417
undo it under bonnet and remove split pin through the hole(under it)
Mini_Andy
Member #: 432
damn it i thought there was gunna be a trick, well i aint no kiddy fiddler so ill get the long nose pliers out then lol
Dangerous - Surely you can't get access this way? Or is it still a case of using long-nose pliers, just without being a contortionist (sp?) at the same time?
Dangerous
Member #: 417
*tongue*
I'm asking - not being funny LOL!!! This is the problems with the internet!!!!
I've always done the contortionist thing, but now thinking that undoing the nuts and master cyl pipes, you could lift the master cyl and actually see the split pin enough to pull out with regular pliers? Or is it still quite a way down?
Dangerous
Member #: 417
The clevis pin is 1 1/4" down when you pull the m/c up.
Think I squashed the splitpin tails together with me fingers,and pointed it the right way in the car.Then yanked the pin out from above
I might have to give this a go next time I do this pleasurable job...
Cheers *happy*
Dangerous
Member #: 417
Some peeps tie a bit of fishing line to the split pin and leave under carpet for the next time,or use a p clip thing.....er.....like what holds the shell on,on a remote control car
I still have an old paperclip in mine from when the clevis pin fell out and i lost the split pin, on the way back from MITP four years ago ! lol
Edited by Turbo Phil on 10th Jun, 2005.
Star Mag
Member #: 375
Leicestershire
I hate doin them best thing is to get ya mrs to do it with their girly hands!!
I'm using the shell-RC-car thingy... Works great.
