Home > General Chat > Titanium brake adjuster
Good idea?
http://item.mobileweb.ebay.co.uk/viewitem?...Id=260790685797
Is it true Carl, that titanium doesn't settle in steel?
Chalkie
Member #: 9764
Northamptonshire.
Hmm sure Galvanic reaction will take place and seeze up?
and I run metro brake adjusters. Much better.
http://www.stainless-steel-world.net/titan...aspx?pageID=173
I took a look around found this so bit of info on here
Edit: site link
Edited by Chalkie on 6th Aug, 2012.
What do they look like? What's the benefit?
Well we were all about to stick Ti bolts in our blocks until the order fell through.
vegar
Member #: 189
I am not an expert on ti, but we use ti in a lot of plate heat exchangers (working for Alfa Laval we are one of the biggest supplyers ww of marine and offshore phe and other equipment) wich are used with sea water. They sure don't corrode
www.shag.no
AWDmoke
Member #: 713
Western Australia
I have necer had problems with titanium threads in carbon steel - but we don't salt our roads!
"Titanium is highly corrosion resistant, and will usually cause more rapid damage to a less resistant active material to which it is coupled. Titanium will usually be the more noble metal and the cathode in the galvanic cell.
Titanium should not be coupled directly to less noble metals, such as magnesium, zinc, and aluminium. These are likely to experience accelerated corrosion and, in the process, titanium may pick up hydrogen which is generated as the cathodic product of the corrosion reaction."
From here: http://www.stainless-steel-world.net/titan...aspx?pageID=173
